Need help with code P1320
Old Mar 6, 2004 | 11:41 AM
CRIS_Y2K_SE's Avatar
In the Hynes Repair manual it states that the code is "ignition signal primary circuit fault" , how can i fix this,what is causing this problem. Thanx in advance for all the help.
Old Mar 6, 2004 | 02:13 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
The code is as follows (P1320):
Manufacturer Control Ignition System or Misfire. Have you replaced the ignition coil packs on your car yet?
Old Mar 6, 2004 | 06:02 PM
no i haven't , but thanx in advance. do you know the price on ignition coil packs.
Old Mar 6, 2004 | 09:28 PM
OT n00bs FTMFCSL
Not offhand, but ask Maxima.org member DAVEB. He can hook you up, I'm sure...
Also, check the for sale forum.
Old Mar 6, 2004 | 09:38 PM
† ErV †
600-700$ dealer job or 80$ per coil from 3rd party source, last time anyone mentioned the price. could have changed since then.
Old Mar 7, 2004 | 04:39 AM
ok well this morning as im pulling out the driveway the whole car is rumbling, shaking i thought it was going to turn off (the car was already warm so its not like if i didn't heat up the car) , the SES light is now blinking for like 30 sec's then it will just stay on. the blinking happened basically through out my whole ride to work. Once i got to work the car wasn't shaking anymore. Is this one of the symptoms of the coils gone bad. I will speak to DAVEB ASAP , he already hooked me up with the MAF sensor.
Old Mar 7, 2004 | 06:46 AM
OT n00bs FTMFCSL
Yes, that sounds like coils misfiring to me. Happened in my S/C'ed Bonneville once. Felt absolutely terrible (but my CEL never came on in that car!)
Old Mar 7, 2004 | 11:21 AM
Im am also getting the TCS OFF and SLIP light on as well, is there any reason for this. Can someone advise me on this. Thanx in advance.
Old Mar 7, 2004 | 12:02 PM
cpdc1030's Avatar
No way, the coils aren't nearly that expensive. I got all six shipped for about $300 USD. You can just install them yourself.
I was getting the same problems, MIL light on, rough engine and TCS Off/SLIP illuminated. I replaced the coils and plugs about five months ago and haven't had any problems since. This issue is very very common on the 99-2000 Max.
Old Mar 7, 2004 | 12:07 PM
thanx for the info ill speak to DAVEB and see what he can do for me, but wait you changed the coils and the plugs right. Was the install hard?
Old Mar 7, 2004 | 12:35 PM
sascuderi's Avatar
You don't have to replace the plugs, just the coils. But if you have 50-60k on the car, might as well do the plugs since you're right there.
I just got the same code as you, P1320, and the SES, TCS, and
SLIP lights all came on at first. Then after the next start up, only the SES light stayed on.
My coils should be in this week and I plan on doing it myself. If you can change your oil and filter, you should be able to do it. From what I've read the back three are alittle harder to do because of the tight area.You have to remove the bolts holding the ignition coils down then just twist them off the spark plug.
I don't know if there is a write-up or pictures on this forum. Anyone else know?
Old Mar 7, 2004 | 12:49 PM
cpdc1030's Avatar
The instructions to change the spark plugs are in the owner's manual. If you don't have one, just go to nissan-techinfo.com and download it for free. If you aren't changing the plugs, the coils are dead easy to replace. Just take off the engine ornament panel, unplug and unscrew the coils, plug in the new ones and screw them back in.
The back coils are a bit tough to reach, make sure you stretch out your back :-)
Old Mar 10, 2004 | 01:31 PM
wtarnette's Avatar
May I ask where you ordered the coils from at that price?
Old Mar 10, 2004 | 02:05 PM
cpdc1030's Avatar
I got them through DaveB at South Point Nissan, you can find his number in the FAQ.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
