Info on changing the dash LED lights.
Old Mar 7, 2004 | 07:39 PM
maximo-SE's Avatar
I dont now if this was posted before but someone was able to turn their stock HU which was green LED to blue.... Is there a HOW TO for this, because I really want to change my dashcolor now.... Please HELP!
Old Mar 7, 2004 | 10:20 PM
thomasd cook's Avatar
As soon as I get my AC LED's figured out I'm going to tackle those lights. I think they are similar to the AC lights I am trying to find. I'm going to get the brightest LED's for that size. Then tap into the illumination ground with the proper resistor.
Old Mar 7, 2004 | 10:49 PM
maximo-SE's Avatar
oh i c..... i read on a post that someone just used a blue sharpie and colored the inside of the stock HU's display to create the blue effect.... d*mn... i wish I can remember who did that....
Old Mar 7, 2004 | 11:45 PM
I think it was Kloogy who did that. I think he just did the key ring light. I have done this. The AC lights had a little blue condom on it which I removed and painted blue with a sharpie. It just made it brighter. If you look at the AC controls and the speedo lights color, they are both the same so I'm pretty sure the lights are the same way. I'll find some LED's and include it in the write-up I did for LED swap.
Old Mar 8, 2004 | 03:39 AM
SoonerFan's Avatar
Cletus
i did it!!
i didnt use a sharpie on the actual display in case i wanted to go back to stock.
here is what i did....
first take off the condom thing on the bulbs which give the green color. now it will have a normal yellowish bulb color. take one of the thin plastic sheets for overhead slides and cut it the size to fit between the display and the cover. color is with a sharpie (i did 3 coats). set the blue plastic piece inside the cover and put it back on. you dont need to tape it or anything. the display touches the cover so it holds it in place. i did the clock the same way. only problem with the clock is it is a little darker and hard to see, especially if the headlgiths are on because it dims. so i cut the red wire going to the clock to stop the dimming.
looks SWEET at night!!!!
finished look
Old Mar 8, 2004 | 06:16 AM
PoLo's Avatar
2-Wheelin it...
i replaced the ac controls with led's...i'm tellin you...i'ts HARD as hell to do it...it's not even a clean job. it's just a small area that it's hard to solder the led's back to stock locations, all while using resistors. i ended up wiring them in parallel to my own wires and then using one of the connections to solder it all too. next i shaved the top of the led. this "scatters" light, for those that know led's. they seem to aim a straight beam, so shaving the top a bit let's it scatter around. i'm telling you, the ac controls light up 100x's brighter. i'm thinking of doing this to my extra gauge cluster as a project. we'll see what happens.
Old Mar 8, 2004 | 08:06 AM
maximo-SE's Avatar
god d*mn sooner... those are nice, matchs well with the blue key ring light. Polo ill check your website out, and btw your interior from your sig is WOW....
Old Mar 8, 2004 | 11:54 AM
IgS's Avatar
IgS
Originally Posted by soonerfan
i did it!!
finished look
[img]
http://images.cardomain.com/member_i...22_53_full.jpg[/img]
sweet good job on that one.
i will actually be trying to make the lcd red. ill c how that one works out. I did the conversion a long time ago, u can check my cardomain site with the www link below. but i got tired of the indiglo guages that i had on, so i put the stock ones back on/made the turn signals blue. ill c if i can actually make the stock guage color just a little bluer, if i cant then ill try and make the buttons on the cd player guage color and the lcd red to match the needles...
there heh
-IgS
Old Mar 8, 2004 | 08:51 PM
ICULookN's Avatar
Keep us updated on the how-to.
Old Mar 8, 2004 | 09:51 PM
IgS's Avatar
IgS
ill be doing it this weekend, will try and take pics.
Old Mar 8, 2004 | 09:52 PM
maximo-SE's Avatar
NICE! cant wait dude.
Old Mar 9, 2004 | 09:55 PM
custommaximaSE's Avatar
I was wondring what kind of leds did you use?
Old Mar 19, 2004 | 11:15 AM
howyoudooin819's Avatar
can anyone help me on how to take apart the stock HU...i already did the A/C control panel...havin a little trouble with the CD Player Unit....any help would be appreciated...Thanks
Old Mar 19, 2004 | 11:25 PM
Wfat type of bulbs did you use or what did you do to the bulbs?
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
