Question for those of you that "cleaned" their MAF sensor and saw an improvement....
Old Mar 11, 2004 | 03:42 PM
NYCe MaXiMa's Avatar
... I just got the torx bit to remove the MAF.. took it off, now how do I clean this thing?
here is a pic someone else took comparing 2 other MAFs.. but just curious, what exactly gets dirty/corroded on this plastic thing that makes a difference?
also how do you clean it? alchohol? WD40?
thanks
Old Mar 11, 2004 | 03:57 PM
MCE's Avatar
MCE
You can get an electronic component spray cleaner that leaves no residue at "radio shack" or other electronic store.
Old Mar 11, 2004 | 03:59 PM
i have something similar to that
i just want to know what i should be cleaning? where does dirt form?
clean the connector? or clean the whole plastic thing?
Old Mar 11, 2004 | 04:04 PM
SoonerFan's Avatar
Cletus
look at the side of it. you will see wires/small metal rods inside a hole. thats what you clean.
here is something that i found that explains how it works. it should help it all make sense to you
http://www.autoshop101.com/forms/h34.pdf
Old Mar 11, 2004 | 04:08 PM
i see what you are talking about.. there are 2 or 3 of them inside.. i see some residue on one.. tough to get in there..
thanks
Old Mar 11, 2004 | 04:11 PM
FanaticMadMax's Avatar
That's a MAF Sensor? I actually never seen it but that's SMALL!!!!
Old Mar 11, 2004 | 04:17 PM
SoonerFan's Avatar
Cletus
thanks
its tough to get in your ear...what do you use??
a q-tip
sorry, im in a smart @ss mood
Old Mar 11, 2004 | 04:20 PM
MAX2000JP's Avatar
I have the one on the pic on the left. I cleaned mine today, but I am not sure I cleaned the right part. I cleaned the slot about a 1/2" from the bottom of the MAF sensor on the left. There is a metal element in there and I cleaned the soot off of it. Not sure if that was the right section, can someone point it out?
Old Mar 11, 2004 | 04:52 PM
yeah
that's what i just cleaned..
Q-tip is not thin enough to fit between the metal thing and the walls... i used a long needle and a little piece of cotton dipped in alchohol..
but get this sh-t.. i stuffed the damn cotton thing inside the sensor!!! now i can't pull it out.. i think i got it out and then i flipped the sensor and it either fell back in or it fell out.. i can't find it outside nor can i shake it out of the sensor or see it through the opening... ****!!!!!!!!!!!!!!!
i am going to cross my fingers and put it back on the car and hope it runs...
damn it
Old Mar 11, 2004 | 05:07 PM
wow... i f-cked something up..
Now it buckles and hesistates. It would at least drive smooth before, but now it just chokes.
Old Mar 11, 2004 | 06:37 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
yeah
damn it
i would not have used a needle. rubbing a metal needle against the wire could easily damage which is why most have used a q tip and squashed the end of it so it would fit down the side. i could see how the piece of cotton could get stuffed in there because the wire leads up to the connector and im sure there is some space up there. did the ses light pop up when you put it back on and it started hesitating?
Old Mar 11, 2004 | 07:24 PM
my SES light is always on anyways because of the faulty Catalytic code.. but i'm willing to bet $ that it's definitely the MAF throwing a code now aswell..
the car is no longer drivable i shouldn't have messed with it..
the idle is all over the place, goes from 300 to 1,500 then jumps around 600-800, then stalls.. non stop hesitation, I barely drove it around the block.. you floor it from a stop and it just doesn't react at all..
i can't even drive it to autozone to get the SES checked to make sure.. damn it.
Old Mar 11, 2004 | 11:23 PM
aussie983's Avatar
if it aint broke dont fix it
Old Mar 11, 2004 | 11:46 PM
who knew, car lost power before, i ossumed cleaning might help..
now it's really done
live and learn i guess
now where do you guys get your MAFs from?
Old Mar 12, 2004 | 12:23 AM
aussie983's Avatar
Dave B. Just get the sensor for around $80 i think it was. His # is in the FAQ's. I dunno if he stocks sensors for 2005 maxima's though
Old Mar 12, 2004 | 06:18 AM
nailz420's Avatar
if it aint broke, only fix it if your arms dont grow out of your **** (old russian proverb)
Old Mar 12, 2004 | 09:56 PM
moyee ruku iz zhopi ne rastut obichno..
i'm normally ok when it comes to working on the car but i was so scared to f-ck up the sensor that i did just that.. lol
are there any differences between 2001 and 2000 MAFs? and are the ones they sell now better than factory? i don't want to have to be without a car again...
does anyone have the part # for the replacement MAF handy?
thanks
Old Mar 12, 2004 | 11:00 PM
Slow Moe's Avatar
Part # for the 01 MAF is 22680-AD210.
Old Mar 12, 2004 | 11:20 PM
thanks
Old Mar 13, 2004 | 12:03 AM
chinaonnitrous1's Avatar
unplug the maf to drive normally up to 2500 rpms.....willl be a lil shakey. I'll trade you a 2k1 maf for a 2k2 maf...haha i have a 2001 maf here. but need a 2002 one.
Old Mar 13, 2004 | 06:32 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
just keep the 2k1 MAF its stronger....im rocking a 2k1 MAF
-J
Old Mar 13, 2004 | 12:12 PM
Are you sure that's the part #?
I just searched JRnissan dealer inventory online and there is no part with that #. Only ending in AD201 for the entire MAF sensor.
anyone else know the #?
Old Mar 13, 2004 | 03:37 PM
Nismotech1's Avatar
confident nissan owner
hey dont sweat it i work at a nissan dealer and you can buy a new one for around 140 bucs they are soooo much cheaper for the 5th gens, gl man
Old Mar 13, 2004 | 08:48 PM
thanks.
Dave B has them for like 100 bucks shipped. Another local dealer may be able to hook me up too. I just want to make the problem go away, I don't care what it costs, within reason ofcouse.. I barely got my car out of the driveway today..
I just hope it will go back to normal, not just drive with a lack of power like it did before I screwed up the MAF completely..
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
