5th gen 300z calipers?
Old Mar 11, 2004 | 08:19 PM
Nismotech1's Avatar
confident nissan owner
hey all i would like some info on if the 300z 90 to 96 front calipers 4 piston would fit on my [/COLOR][/SIZE][/FONT][SIZE=3][COLOR=Black]2k1 max and what if any mods need to be done
Old Mar 11, 2004 | 08:21 PM
Nismotech1's Avatar
thank you for the info, this was my first posted thread
Old Mar 11, 2004 | 08:55 PM
kwd2kSE's Avatar
Do you want to use the 300ZX size rotors(11") that you mill down 4mm, or the BBK that Matt93SE is selling that uses the '04 Max rotor(12.6"). If the last one, here's the link.
http://forums.maxima.org/showthread.php?t=275821
My white 5th Gen was the test mule for development of this kit, and the one that uses the stock caliper.
Mike
Old Mar 12, 2004 | 09:12 AM
panda_1's Avatar
i want the bbk. but will it fit in the stock 17's?
Old Mar 12, 2004 | 09:19 AM
Larrio's Avatar
The Definitive AE Master
no, its a impossible fit
Old Mar 12, 2004 | 09:37 AM
kwd2kSE's Avatar
Matt makes a second BBK that uses the same 12.6" rotor, but with the stock 2000/2001 front caliper that fits behind the 5th Gen 17" wheels. Here's the link.
http://forums.maxima.org/showthread.php?t=291150
Yep, fitted on my car again.
Old Mar 12, 2004 | 05:47 PM
Nismotech1's Avatar
thanks for the info, i would like to know if the 300z calipers fit with the 6th gen rotors, without milling them?
Old Mar 12, 2004 | 07:33 PM
kwd2kSE's Avatar
If you buy Matt's kit, no milling of rotors needed. The entire kit is bolt on. No grinding, milling, rubbing, spacers, etc. needed. But realize you must have the kit which includes the bracket and bolts that move the caliper out from the hub because of the larger rotors. Look on the link I posted above, last page for the link to his web site and pictures. You'll see the mounting bracket.
Old Mar 25, 2004 | 04:18 PM
Nismotech1's Avatar
i checked the specs on the 5th gen rotors diameter and the 300z rotors and they are both 280mm or 11.02 inchs so why do the have to be milled at all? please help me understand.
MAXSE5SPD
Sep 17, 2022 04:00 AM
bbsitum
Sep 11, 2015 04:55 PM
Violator
Sep 9, 2015 10:14 AM
beerman1378
Sep 8, 2015 02:19 PM
Lowered_a33
Sep 1, 2015 07:49 PM
