Reset ECU after installing exhaust?
Old Mar 12, 2004 | 09:39 PM
maxcosity's Avatar
Is it necessary/recommend to reset the ECU (unplug the '-' (negative) battery cable for a few minutes) after installing an exhaust?
I know it is recommended for an intake.
Just want to make sure - although I doubt it would hurt.
Old Mar 12, 2004 | 10:27 PM
panda_1's Avatar
regardless i would do it, and let my ecu remap all the curves with the exhaust.
Old Mar 12, 2004 | 10:46 PM
crispykid717's Avatar
Bigger than Jesus
except for a 2k3 unplugging the - terminal won't reprogram the ecu.
Old Mar 13, 2004 | 07:10 AM
maxcosity's Avatar
I have a 2K3.
Old Mar 13, 2004 | 09:10 AM
ICELANDIC MAX's Avatar
Originally Posted by maxcosity
I have a 2K3.
for 02-3, you don't unplug the battery
http://www.technosquareinc.com/350reset.htm
http://maxima.theowensfamily.com/ecu.asp
Old Mar 14, 2004 | 12:40 PM
custommaximaSE's Avatar
Thats weird i have 2000 and i install ingen intake and cat back exhaust and the y-pipe.
i did not reset my ECU ,And the SES light never come on it's been 6 month now no problem.
Is there something wrong with my ECU?
Old Mar 14, 2004 | 12:56 PM
njmaxseltd's Avatar
Resetting the ECU only clears stored error codes, it does not erase or reset stored operating parameters.
The ECU will immediately learn and adjust for any performance mods you install by looking at MAF (air flow) readings and O2 sensors.
Old Mar 15, 2004 | 02:23 AM
GreekMaxima's Avatar
i did not reset my ECU either!!
Old Mar 15, 2004 | 08:46 AM
panda_1's Avatar
how would you reset your ecu without disconnecting your battery. doing it from the inside of the car.
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
