Passenger Window Possessed
Old Mar 15, 2004 | 02:50 PM
jk2addict's Avatar
Apparently the games have begun. Two days after bringing her home, the passenger side window is freaking.
If I put the window up all the way, it immediately goes back down about 4".
While I'm sure it's the safety system, God knows why it started now today at 5:15PM.
It there any solution other than a computer reset?
Old Mar 15, 2004 | 02:57 PM
SoonerFan's Avatar
Cletus
is anything stuck in the window track that it could be hitting? it will roll back down if it meets any resistance
Old Mar 15, 2004 | 03:19 PM
jk2addict's Avatar
Nope. That was my first thought. Clear as a bell. Even funnier, if I do quick little pulls on the window button, it will go up a half inch at a time. If I time that right, I can get it all the way closed. If I just let it go up on it's own, or pull the button solid until it's all the way up, it goes back down that 4". Silly window.
It could be worse I guess:
02-088 SEP 02 Body - Sunroof Operates By Itself
That sunroof TBS has been around forever...at least since 2000. :-P
Old Mar 15, 2004 | 03:20 PM
SoonerFan's Avatar
Cletus
disconnect the battery for a little bit. it might reset it
Old Mar 15, 2004 | 03:28 PM
jk2addict's Avatar
Worth a shot. Wonder what other kinds of havoc that will create?
Worst case, it's going in Wednesday morning for a reset along with the Sentra the group service.
Old Mar 15, 2004 | 05:02 PM
jk2addict's Avatar
Just a side note Stupid me finally realized the window switchs are two position. THis problam is not present when I close the window using position one. It's only position two/auto that the passengert window freaks out. Go figure.
Old Mar 16, 2004 | 06:39 PM
jk2addict's Avatar
I know you can reset the ECU. What about the BCU? I would assume that is where the problem lies.
I can't quite get this to work, or rather I don't know how to tell if it was indeed reset.
http://maxima.theowensfamily.com/ecu.asp
Old Mar 17, 2004 | 04:23 PM
jk2addict's Avatar
Just for the next person who has this problem.
They had to pop the door panel nd reset the window motor itself.
Old Mar 17, 2004 | 06:57 PM
hansolo1's Avatar
I had this same problem myself. I brought the car in and they reset the window motor. Then the next day I went to put the window up and it went back down again on it's own. I brought it back and they re-aligned the window in the trakc or something to that effect and they told me if it does it again then they would have to replace the window motor. Luckily aligning the window or whatever they did fixed it. So don't be surprised if reseting the motor doesnt't fix it.
Old Mar 18, 2004 | 06:30 AM
xosder's Avatar
Cool. At least I know what they need to do. Since I just encountered the same problem.
Old Mar 19, 2004 | 10:31 AM
jk2addict's Avatar
SOB! Now my drivers side windows is doing the same damn thing today. $20 says there's a logic problem with the BCU/Motors on these models.
Even stranger for the drivers side: it works right the first time, but none thereafter until the car is restarted.
Wonder how long it takes until a TSB shows up for this.
Old Mar 19, 2004 | 04:03 PM
jk2addict's Avatar
Ha, of course. Ony the way home, the damn window worked fine. WTF?
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
Luev
Sep 30, 2015 11:50 PM
