SS lines on Y2k
Old Mar 15, 2004 | 03:18 PM
exunaja's Avatar
SS lines on Y2k
I recently purchased a set of techna fit SS lines from one of the GD in this forum.
I tried to put them on over the weekend and realize it was way to short for the rear brake and also the front. Any idea about the length of this SS lines? I don't feel comfortable installing it knowing that the length is not closely match the oem nor I can compare it to any other brand such as Goodridge since I have none.
Does anyone in the forum has installed this brand or Goodridge?
brake guru please shed some light, I am one confuse max.
TIA
Old Mar 15, 2004 | 08:25 PM
exunaja's Avatar
Originally Posted by exunaja
I recently purchased a set of SS lines from one of the GD in this forum.
I tried to put them on over the weekend and realize it was way to short for the rear brake and also the front. Any idea about the length of this SS lines? I don't feel comfortable installing it knowing that the length is not closely match the oem nor I can compare it to any other brand since I have none.
TIA
no one can give me any advice?
Old Mar 16, 2004 | 03:20 AM
spirilis's Avatar
Are you sure they are too short, or do you just need to adjust the center bracket? (it can be moved...)
Old Mar 16, 2004 | 09:19 AM
exunaja's Avatar
Yes I have move around the center bracket on the line, but the center bracket is sitting on a fix bracket on the rear beam, I did a dry run with the OEM brake line on the rear brake remove and tried the SS line,but it is way to tight.
No room for play, 'cause I check Greg's maxima (99) with goodrich ss lines an the picture showing some room for the line to stretch.
any idea?
Thanks for reply
Old Mar 16, 2004 | 01:38 PM
exunaja's Avatar
No room for play, 'cause I check Greg's maxima (99) with goodridge ss lines an the picture showing some room for the line to stretch.
any idea?
Thanks for reply
FYI:
here is the copy of the email I receive from the techna-fit
-----Original Message-----
From: Trotter Stuart [mailto:technafit@earthlink.net]
Sent: Tuesday, March 16, 2004 3:46 PM
To:
Subject: Re: SS brake line for Nissan Maxima 2000
The fronts are about [B]20.75 inches overall [B]. The rears are about [B]23.25 inches overall [B]. The rears are longer than the fronts.
> From: ">
> Reply-To: <>
> Date: Tue, 16 Mar 2004 15:03:56 -0600
> To: <technafit@earthlink.net>
> Subject: SS brake line for Nissan Maxima 2000
> Hi, I have recently purchased Techna-Fit brake line kit for my Nissan
> maxima 2000 from one of the retailer online (NIS-1120). Can you tell
> me exactly how long in the SS line suppose to be for the front and
> rear brake, because the item that I received was way to short compare
> to the OEM. I am worry that the brake line has no room for movement
> since it is so short compare to the OEM
> Thanks,
> Erwin
Old Mar 16, 2004 | 04:28 PM
spirilis's Avatar
Yeah, the rears are a bit longer. You know, come to think of it I'm not sure what brand I have. I bought mine from Automax_95's GD last fall. Don't recall a brand name listing for it. The hoses work great, and fit perfectly for me.
Old Mar 16, 2004 | 05:35 PM
aussie983's Avatar
yep exunaja got them off automax too, as did i, so yours are probably the same technafit ones.
I havent installed them yet, so i dont know if they fit. Will be doing install soon tho.
Old Mar 16, 2004 | 07:52 PM
exunaja's Avatar
Yes mine all the same length, I guess they packaged the same item and I am so unfortunate to received it. I will contact Automax to resolve this.
"A great brake set up is useless without the SS lines"
Thanks folk, anywone with goodridge SS lines please let me know the overall length.
Old Mar 16, 2004 | 07:53 PM
exunaja's Avatar
Thanks folk, anyone with goodridge SS lines please let me know the overall length.
Old Mar 16, 2004 | 08:16 PM
aussie983's Avatar
how long are your lines?
Old Mar 16, 2004 | 08:27 PM
exunaja's Avatar
20.75 inches on all of them.
Old Mar 16, 2004 | 08:31 PM
aussie983's Avatar
think u got a set for the wrong car. I hope mine is the correct one. i dont know maybe mine has too much slack, since the front ones are only supposed to be 21
.mines the same for all 4 around 25 inches.
Old Mar 16, 2004 | 08:33 PM
exunaja's Avatar
not according to Jason, but I wouldn't lie for my own safety. just double check your SS lines length.
Old Mar 17, 2004 | 07:55 AM
exunaja's Avatar
OK people, thanks for your input. I resolved my issue and I will be getting a new correct SS line set soon.
I believed Techna-fit packaged the wrong item for nissan maxima 2000 fitment, unfortunately I am the one that got it.
FYI: This is the correct length according to techna-fit for year 2000 maxima application:
Front: 20.75 inches overall
Rear: 23.25 inches overall
I used speed bleeder from www.speedbleeder.com to make bleeding is easier.
If you have a longer SS lines than the one Techna fit suggested, please check the fitment on your car, that is possible you have to much slack and it will increase the fluid travel distance to your brake caliper. I have no idea how this will affect your car braking performance.
Disclaimer!
I, Exunaja have no relation with Techna-fiit/SpeedBleeder nor getting any benefit by providing this information to you. You are responsible for your own safety.
Thanks Automax_95 for a great setup for the reasonable cost and responsiveness in answering Q's.
Old Mar 17, 2004 | 08:20 AM
spirilis's Avatar
I can confirm that a great brake setup is enhanced by SS lines--a stock setup is virtually transformed by them (much tighter pedal feel, makes me feel much more confident in my brake system...)
Old Mar 17, 2004 | 10:17 AM
aussie983's Avatar
Um so i guess my lines are almost 4 inches in rear and 2 inches for the fronts too long?
Anyone know how this would affect the braking?
Would it still be ok to install them, or should i get the lines with the stated length above?
Old Mar 18, 2004 | 07:13 AM
exunaja's Avatar
another techna-fit answer, but not directly answering question.
Sent: Thursday, March 18, 2004 9:34 AM
To:
Most stainless steel lines are made about 1/2 inch longer than stock. The
reason for this, is that stainless steel lines are not stretchable, OEM
style rubber lines have some give. Sometimes something is lost in
communication between distributor and customer as to exactly what kit fits.
> From: "Erwin "
> Reply-To: > Date: Wed, 17 Mar 2004 13:10:34 -0600
> To: "'Trotter Stuart'" <technafit@earthlink.net>
> Subject: RE: SS brake line for Nissan Maxima 2000
> Thank you, since you are the expert, any ideas how's the length of the SS
> line affecting the braking performance? One friend received his SS line for
> the same set up but about 24-25 inches in overall length for all of them? So
> now he is very confused.
> Thanks
> Erwin
Old Mar 18, 2004 | 11:27 PM
aussie983's Avatar
hmm that still doesnt answer the question. What i want to know is if they are too long (to work properly) otherwise ill see if i can get the proper ones. I dont want to have even worse lines that sag worse than stock ones.
btw it does say nis-1120 on the front
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
ivorton23
Sep 28, 2015 09:08 PM
Taino14
Sep 24, 2015 02:51 PM
