How much torque...
Old Mar 18, 2004 | 11:16 AM
takkar's Avatar
How much torque...
how much torque do you need to tighten the bolts on the wheels? I'm putting back my original rims and i don't know how much to tighten the wheel nuts...i don't have a torque wrench so roughly how many turns would that be?
Old Mar 18, 2004 | 12:58 PM
01SE02SER's Avatar
Faster than a speeding bullet...
If you had a torque wrench, it should be set between 72 and 87 ft-lbs.
Manually, this actually isn't too much, as the nuts can actually be removed without much effort. When I used to have my Civic, I used to manually tighten the nuts by actually stepping on the included wrench until I heard the metal-on-metal rubbing sound. Now I know that meant waaaay too much torque.
Manually, I would tighten each nut until you can't easily push the wrench to loosen the nut. I can't say exactly how many turns that is, though. I hope that makes sense. But I would recommend investing in a torque wrench to get the nuts to the right setting just in case.
Peace.
Old Mar 18, 2004 | 04:57 PM
spirilis's Avatar
Yeah, I've tightened steel wheels by stepping on the tire iron--that is GROSSLY way too much torque, actually it's probably more than double what is recommended. You do NOT want to do this with alloy wheels. 72-87 ft/lbs isn't really weak, but it's not as tight as you'd think. Best buy a torque wrench (1/2" drive click-type) to be sure.
Old Mar 18, 2004 | 06:08 PM
Maxpat82's Avatar
I always torque to 100ft/lbs
Torque stick on impact gun!!
or torque wrench on aftermarket chromed nuts!!
Old Mar 19, 2004 | 11:52 AM
takkar's Avatar
I usually step when tightening the nuts on steel rim of my Civic too..but just want to be a little craeful with the Max since it doesnt have steel rims and i don't want to mess up anything..
thanks guys...
aackshun
Dyno Discussion and Slips
Sep 9, 2014 06:42 AM
grey99max
62
Jul 29, 2009 01:35 PM
HNDA ETR
Dec 24, 2007 09:29 PM
