ODBII Error - 0420 Catalyst System Efficiency Below Threshold Bank 1
Old Mar 18, 2004 | 01:02 PM
oscarthemooch's Avatar
Does anyone know what this error refers to? Is it the O2 sensor or does the catalytic converter need to be replaced?
Old Mar 18, 2004 | 01:11 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
it pertains to a tsb released from nissan. the newly updated tsb calls for a ecu flash which is covered under 8yr/80k federal emissions warranty. the flash has solved the problem for most but other have had to replace their cats in the event it did not solve it.
Old Mar 18, 2004 | 03:25 PM
nm's Avatar
nm
Does this TBS apply to 2000-2001 or 2002-2003 maximas?
Old Mar 18, 2004 | 05:14 PM
sloppymax's Avatar
it includes 2k cali specs and all 2k1 which are cali spec. if you dont know which you are, pop the hood and count the number of o2 sensors. if you have 4 then you are cali spec.
Old Mar 18, 2004 | 08:15 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
If U installed headers and have no cats at all U MIGHT get this code. This code basically means the Cat is not working. Resistor mod will cure that
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
