Idle Question.
Old Mar 22, 2004 | 10:39 AM
AcidReflex's Avatar
Idle Question.
What does you car idle at? Mine seems to be idling pretty low. I want to know what is standard. Thanks.
John
Old Mar 22, 2004 | 10:40 AM
AcidReflex's Avatar
RPM's that is. :-p
Old Mar 22, 2004 | 10:47 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Originally Posted by AcidReflex
RPM's that is. :-p
2k-2k1 autos idle around 675-725. i had mine bumped up a tad to 700-725 with a consult to help with the noise i was getting from the compressor due to the udp. i would assume the same would be true for the 2k2-2k3.
Old Mar 22, 2004 | 11:00 AM
VMaximus02's Avatar
Follow the procedure (for 02'-03') below to correct your idle speed to OEM's spec:
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
Operation Procedures
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old Mar 22, 2004 | 11:06 AM
Ammi's Avatar
350 Detroit Muscle
Mine is at about 600. It's normal.
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
