Need Immediate Help On Brakes!
Old Mar 27, 2004 | 11:45 AM
aussie983's Avatar
I have the wheel off and the caliper off right now, and i cant seem to freakin get the 17mm bolts off that hold the torque member.....!!
Anyone know how to take them off?
Are the supposed to be this tight?
Old Mar 27, 2004 | 03:06 PM
njmaxseltd's Avatar
Use a 1/2 in drive breaker bar. They'll come off.
Old Mar 27, 2004 | 03:12 PM
2002 Maxima SE's Avatar
Take a hammer and whack the wrench a few times. Those bolts see lots of environment (dirt, water, ice, salt, etc) and can become stuck over time. Try some WD-40 and let it soak in for a while.
Old Mar 27, 2004 | 07:29 PM
aussie983's Avatar
thanks guys
i got a 18" torque wrench, 1/2 inch drive, and after some hard elbow grease i managed to get those damn screws off
Old Mar 27, 2004 | 07:30 PM
00MaxSE's Avatar
Pointy Elbows
Yeah I did my front brake last weekend and to get those bolts off I soaked them with Liquid Wrench and then used a long handle rachet and wacked the end with a rubber mallet.
Try it out.
Old Mar 27, 2004 | 10:47 PM
Ammi's Avatar
350 Detroit Muscle
Invest on a can of PB Blaster.
Old Mar 27, 2004 | 11:55 PM
TEEdotMAX's Avatar
HORROR STORY: i was changing my brakes & rotors. got 3 of the 4 done & a f'n bolt head snapped in the caliper bracket. i tried drilling & allen keying it out myself but the allen key only rounded out the inside of the bolt. i was checkin to see how much a caliper bracket costs. turns out nissan only sells the entire caliper assembly... for over $250. i ended up taking it to a machine shop. 40bucks later i had the bolt drilled out. 4 hardware stores later i found a replacement bolt. i'm still traumatized!
Old Mar 28, 2004 | 06:38 PM
aussie983's Avatar
ouch! damn i was pretty close to that too, I had stripped both screws a fair bit, cuz i was using a $hitty adjustable wrench, and i was afraid to try more. So i decided to invest in a 18" torque wrench, since i needed to torque the lugs nuts at the proper range too.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
