wild idle after foglight install
I just installed stock foglights on my 2000 max. In the manual it said to unplug battery's negative terminal, which I did. After I was done and started up the car, right away I noticed that idle was all over the place, especially when the engine is cold. When I stop in traffic, the idle holds at 650, then after about 5 secs it drops to a little over 500 and car starts to shake. I've had that before but not as much, and even less after I changed the plugs and used a can of bg44k.
I am wondering if I could've messed something up while installing the fogs. Could unplugging the battery cause this?
Originally Posted by thomasd cook
By unplugging the battery you reset your ECU. It'll be alright after a few days. It just has to relearn everything.
my guess is you messed something in the fusing, blew a sensor or it's simply a freak concidence.
Originally Posted by EvilRoadsVictim
it takes 24 hours for that to work, and the idle is a constant spec in the ECU and does not change, even after reset.
bryants95max
10-02-2015 12:52 PM
97_GXE
20
09-17-2015 08:12 PM
ballerchris510
09-10-2015 09:35 PM
Hdnseek
09-09-2015 05:55 AM
