Noise coming from front suspension
Old Mar 30, 2004 | 10:02 AM
MAX2000JP's Avatar
I am getting a weird noise coming from the passanger side suspension. It is a popping noise, almost sounds like something is about to fall off. Anyone have any clue to fix this?
Old Mar 30, 2004 | 10:16 AM
Igor911's Avatar
You need to be more specific. What suspension are you running?
Old Mar 30, 2004 | 11:25 AM
MAX2000JP's Avatar
I am running the OEM suspension. I was previously running Eibach springs and swapped back to the OEM's. I checked and looked if everything was tight, all the bolts are in place. The noise is a poping noise; it seems that it makes the noise when the shocks are compressing over a bump.
Sorry for the short post last time, I was in a hurry.
Old Mar 30, 2004 | 11:56 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i had a popping sound coming from my right front strut and nissan replaced it for free. the noise went away until it started up on the other side so they replaced that strut for free. all the noise went away then i replaced them with gr-2 and have not looked back. edit-the noise only showed up when i turned to lock at a low speed like turning into a parking spot but it would pop on the opposite side i turned to.
Old Mar 30, 2004 | 12:05 PM
UMD_MaxSE's Avatar
Got Bent?
noises while turning may be because of a bad strut bearing... the small plastic piece that the strut body travels on when turning... If that thing is bad, the whole strut/spring assembly may not be rotating freely and causing those noises...
Old Mar 30, 2004 | 12:08 PM
spirilis's Avatar
Mine's been making that same noise since I installed Illuminas on stock springs last week... every so often when landing on the front suspension kinda hard, I get a hollow "pop" noise from the front passenger area, especially when the front end lands off a speed bump. I think the front passenger side strut I did in a hurry, but I remember making sure everything was aligned (strut bearing, bushings, etc)
I hear this while turning or going straight... I've heard it while cutting into a left turn quickly (when the front right spring compresses), and it happens all the time when the front-end lands after going over a speed bump.
Old Mar 30, 2004 | 12:09 PM
spirilis's Avatar
Also note that the noise didn't start up until a few days after the install... almost as if the condition has developed and is worsening over time.
Old Mar 30, 2004 | 12:18 PM
MAX2000JP's Avatar
Same situation here....
Old Mar 30, 2004 | 12:27 PM
2k2nyc's Avatar
Same here, but it only happens to me when it rains.
Old Mar 30, 2004 | 01:40 PM
MAX2000JP's Avatar
Fixed my problem. The nut on top of the strut was loose, so I torqued it down. I guess I should have checked that after Carquest put the fronts back together.
Old Mar 30, 2004 | 07:10 PM
Cutler's Avatar
Why are you giving advice on something you know nothing about......?
Old Mar 30, 2004 | 07:46 PM
housecor's Avatar
Sprillis and 2k2nyc - do this: With your car parked, bounce you car up and down on the passenger side. I could hear the noise this way and it made it easy to hunt down the source. In my case, the end of the bottom of the spring was scraping against the perch. I reseated the spring away from the edge of the perch just a bit and made sure the isolator was placed properly. No more noise.
Old Mar 30, 2004 | 07:54 PM
irish44j's Avatar
retired moderator
I had what sounds like the same thing....turned out the strut was bad, replaced under warranty....you probaly will not be able to reproduce the sound by bouncing the car, and there is no visual sign that the strut was bad...but have the dealer replace the strut under warrany and you should be set.
Old Mar 31, 2004 | 12:14 AM
spirilis's Avatar
I hope my Illumina isn't bad... not exactly wanting to go through the process of having it replaced and having another alignment done
What's the torque spec for the top nut? (IN FOOT-POUNDS, NOT NEWTON-METERS...)
I'll have to inspect the spring's perch; that is a plausible explanation, although I went through some effort to ensure the spring was seated properly, it could be too close to the perch...
Old Mar 31, 2004 | 06:53 AM
housecor's Avatar
Let me know if you find anything. Even though I resolved the ugly noise coming from the bottom of the spring, I still have an issue with something sounding loose on the front passenger's side. I've checked everything I can think of:
1. Bolts are torqued to spec
2. Spring is seated properly
3. Top is facing out on the tophat
4. Strut bearing is in good condition
5. Can't be a wheel bearing since it goes away when I put on OEM strut
This loose sound on the passenger side has been ongoing since I installed the Illuminas. If this passenger side sound is happening to many Illumina owners I'm getting concerned. I'm growing confident the issue may be the strut itself since the loose sound went away when I swapped back to OEM and came right back when I reinstalled the Illuminas.
Let me know if you guys have any other ideas.
Old Mar 31, 2004 | 06:56 AM
housecor's Avatar
Check you Illumina documentation - If I remember right it's really low: 10ft lbs.
Old Mar 31, 2004 | 07:11 AM
2k2nyc's Avatar
I have th HP Tokicos w/ the same problem
Old Mar 31, 2004 | 08:01 AM
spirilis's Avatar
Huh, the fronts I used 50 ft/lbs, rears I did it by hand kinda estimating based on how compressed the bushing looked (they said something about 7-10 ft/lbs for shocks of a certain type, I figured that applied here...)
I'll try retorquing these to 10 ft/lbs after raising the car a little bit to decompress the bushing...
Old Mar 31, 2004 | 08:26 AM
housecor's Avatar
50?! Ouch, I remember the Illumina documentation warns against overtorquing the top hat bolt. They said it can damage the "sensitive adjustment mechanism" Hope no damage has been done. Lemme know.
Old Mar 31, 2004 | 08:51 AM
spirilis's Avatar
Hrmm. Something just doesn't sound right about that. The adjustment piece in the middle shouldn't be affected by the clamping force between the top hat and the top threading--the adjuster goes down the center of the rod.
If anything, I'm worried that I've permanently cracked the rubber bushings, and will have to replace them sometime soon.
Old Mar 31, 2004 | 09:26 AM
housecor's Avatar
What rubber bushings are you referring to?
Old Mar 31, 2004 | 09:30 AM
spirilis's Avatar
Maybe it's the strut bearing I'm referring to... when you tighten the top hat nut on the front struts, you have to be compressing *something*
Old Mar 31, 2004 | 09:40 AM
spirilis's Avatar
Actually, forget about that--the proper torque spec for the front struts' top hat nut IS 44-65 ft/lbs (looking at a parts explosion diagram from the shop manual through alldatadiy.com)
Exact specs are 59-88 (6.0-9.0, 44-65) which is represented as Nm (kg*m, ft/lbs)
Also, for the rears the top hat nut is 20-24 (2.0-2.5, 15-18) so 15-18 ft/lbs...
While I'm on a roll, here's the torque specs for the strut tower nuts--
Front: 32-38 ft/lbs
Rear: 18-25 ft/lbs
I did my fronts to ~35 ft/lbs, and the rears kinda "by-hand" using a ratchet
Old Mar 31, 2004 | 09:53 AM
spirilis's Avatar
Also, there's a TSB for noise from the right front suspension, Reference# NTB00-030, Classification FA00-003
APPLIED VEHICLE:
2000 Maxima (A33)
SERVICE INFORMATION
Use the service procedures in this bulletin to effect repairs if a 2000 Maxima (A33) exhibits specific noises from the right front strut during certain driving conditions such as those described below:
- Click or clunk noise from the right side when turning right. This may be caused by contact between the tip of the power steering switch bolt(s) and the RH upper spring seat.
- Squeak or squish noise from the right side when applying the brakes. This may be caused by spring/seat contact in the RH strut assembly.
Service procedures call for the following:
1. Add 1 washer to bolt head which supports the Power Steering switch. There are 2 of them, and the PS switch is very close to the right-front strut tower nuts.
2. Remove the right-front strut assembly, remove the spring, remove the rubber lower spring protector (rubber collar), and put a bead-width amount of 3M Scotch-Grip Rubber and Gasket Adhesive to the center/inside of the spring protector
3. Reinstall the rubber spring protector leaving about 1/4" overlap off the tip of the spring. Reinstall the spring/strut back onto the car.
I'd probably advise anyone who changes springs/struts to use that 3M Scotch-Grip stuff on all the spring protectors on all the springs, overlapping it by 1/4". Call this a new "standard procedure"
I'd bet that this is my problem, since I never noticed this problem with the old struts (therefore I doubt it's the PS switch banging against the strut tower nuts...)
Old Mar 31, 2004 | 09:56 AM
spirilis's Avatar
APPLIED VEHICLE:
2000 Maxima (A33)
SERVICE INFORMATION
Err, whoops, erroneous analysis -- the Power Steering switch bolt problem is that the LOWER part of the bolts are banging against the upper spring seat, which could be my problem... the washers raise the bolts up a little so there's more clearance under the strut tower. So this could be my problem, in addition to the spring (I'll have to see if my spring protector is exposed a little, and if it's not, I'll try the power steering bolt washer method)
Old Mar 31, 2004 | 10:20 AM
gkstar's Avatar
Had now have again same issue. First time problem was not enough lubrication between the rubber part that threads on the spring and bearing. coilovers a little different but some lithium grease solved the prob for about 5 months, back to the drawing board once it stops raining and warms back up.
Old Mar 31, 2004 | 02:33 PM
housecor's Avatar
Actually, my 2k3 came with the scotch-grip crud on the isolator. And yes, I would recommend putting it on the isolator for aftermarket springs. Mine shifted and caused noise without this.
Old Mar 31, 2004 | 06:29 PM
spirilis's Avatar
Mine's definitely not the power steering switch, as I've shimmed the bolts with a couple washers (2 of them per bolt, after that the bolt won't catch its threads...) and it still makes this noise.
Looks like I'll have to buy some of this scotch-grip crap and pull apart the front right strut...
At least the noise isn't that much of a pain for now... it only happens when I hit the front right suspension hard, and even then the noise is similar to going over some bumps, which I can't hear with the stereo up anyway
This'll probably be a 1-2 week from now kinda job...
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
