GAB - Pix and HP increase?
Old Mar 30, 2004 | 05:01 PM
3Pedals_6Speeds's Avatar
After hearing asbout GAB's for so long, I'm wondering what people's GAB looks like, and what HP gains they've achieved.
Old Mar 30, 2004 | 05:21 PM
bigdo26's Avatar
go to my homepage for my GAB/OSCAI.
Old Mar 30, 2004 | 06:07 PM
Fezzik's Avatar
http://home.insightbb.com/~dwh/GAB.htm
here is one i did using a hanger. Cheap and effective. This way you do not ruin your actual air filter holder.
Old Mar 30, 2004 | 06:40 PM
SoonerFan's Avatar
Cletus
cheap my homepage too
HP increase is minimul but sound is nice
Old Mar 30, 2004 | 07:37 PM
BP's Avatar
BP
pretty good free mod. i tried the example posted by Fezzik, very easy, reversible, seems to provide the best improvement in air flow while being otherwise stock.
it noticeably increases the sound of the intake under hard accelleration. that's the only time you can hear the difference. as far as performance the car seems to pull a little better under all conditions but don't expect a huge difference. haven't had a long enough evaluation period to guage any effect on gas mileage....but i'll definitely need to keep the (growling intake induced) lead foot effect into consideration.
Old Mar 30, 2004 | 08:54 PM
bgates1654's Avatar
I am going ot be dynoing my TS ECU on sunday with a group of other people. I took out my coathanger GAB to get a better idea of what the CEU is giving me. I plan on going first that way when I am done I can put the GAB back on, reset the ECU, drive it a bit then dyno again to see if the GAB gives decent gains. I might not be giving it enough time to thoroughly learn it but we should see something.
Old Mar 30, 2004 | 09:01 PM
bigdo26's Avatar
well if this helps any:
I ran with my GAB at the drags, hooked up to piping that brought in cold air (kinda like the ram air thing they've been discussing). I trapped an average 94.5 mph.
I then tried 2 runs with the air filter removed (and the piping so that nothing got sucked up thru the piping) and my traps were identical, which shows equal power production.
That leads me to believe that the GAB/OSCAI works just as well as having no restrictions at all in the airbox. Since putting an air filter in creates more restictions than no air filter, the GAB/OSCAI reduces those negative affects
Old Mar 30, 2004 | 10:03 PM
ABS's Avatar
ABS
You can check my home page too.
AcuraLegend
Oct 17, 2016 08:47 PM
trsandrew
Apr 8, 2016 06:45 PM
maxinout93
Oct 31, 2015 02:04 AM
trsandrew
Oct 25, 2015 02:47 PM
Sep 27, 2015 08:37 AM
