My car is pulling slightly to the right ... ?
Old Mar 31, 2004 | 10:36 AM
BUDDHAZMAX's Avatar
Hello guys and gals,
I just rotated my tires (front to rear and vice versa) and now my car pulls slightly to the right. I was wondering if anyone else had this happen after they rotated their tires. Any suggestions would be helpful and I do apologize if this was already discussed in any previous threads. (I had no time to check, cuz i'm at work...and i shouldn't even be on the internet during work hour. hehehehe) Thanks in advance for any and all help
BUDDHA
Old Mar 31, 2004 | 10:37 AM
NT2SHBBY
if the car pulls, its an alignment issue...
Old Mar 31, 2004 | 10:42 AM
SoonerFan's Avatar
Cletus
or a low tire
Old Mar 31, 2004 | 03:44 PM
trey
Actually it could be one of many things, not primarly a alignment issue. It could be bad tire, a brake problem, a suspension problem or just about anything.
The most common reason for needing an alignment is the tire wear. When you have one, and only one edge of the tire that wears more then the other edge or uneven tire wear.
Old Mar 31, 2004 | 03:57 PM
BUDDHAZMAX's Avatar
Is it possible to switch both front tires ? (flip flop them) And are stock potenzas directional ? excuse my unknowing of this issue
Old Mar 31, 2004 | 05:19 PM
GLE2000's Avatar
Do the former from tires show any signs of feathering?
Old Mar 31, 2004 | 06:57 PM
Ammi's Avatar
350 Detroit Muscle
I don't think craptenzas are directional.
Was your car pulling before you rotated your tires?
Old Mar 31, 2004 | 07:45 PM
BUDDHAZMAX's Avatar
You know what Ammi, I honestly don't know...I also drive a 93 MPV and the I've gotten used to the big difference in steering feel from both...but as far as i could tell, i haven't noticed any pulling before i rotated them. about my other question, do you think it'll be alright if i switched the front tires (swap)?
Old Mar 31, 2004 | 07:48 PM
Cutler's Avatar
check the obvious first, the tire pressure. If that's not the culprit work through the suspension, check the struts and then alignment. Could be a bad ball joint, bent tie rod. Check all that then post back for more help
Old Mar 31, 2004 | 07:55 PM
BUDDHAZMAX's Avatar
Thanx alot...will do !
Old Mar 31, 2004 | 08:13 PM
Cutler's Avatar
Originally Posted by Igor911
I am not very smart and I like short buses, anyone seen my helmet?
Don't be so mean to yourself......
Old Mar 31, 2004 | 08:25 PM
Cutler's Avatar
No problem, glad we all could help!
Old Mar 31, 2004 | 08:37 PM
DaBoxSE's Avatar
MPV!! My girlfriend drives a 92 with 4wd go figure.
I am having the same issue with my car. Mine pulls a little to the left after I get the clutch disc TSB done from the dealer. I need new tires, but the stock shi-tenzas are not wearing unevenly. So it doesn't look like the alignment.
Old Mar 31, 2004 | 08:40 PM
2001maximase5sp's Avatar
with all my past experiences , your rears will wear slightly different from the front tires , if you've ever had a front wheel drive car and hardly ever rotated your tires , the rears always seem to last twice as long , my rears are always "flater" and the fronts are always alittle more rounded , from turning , plus more force is on the fronts , being the drive tires . Just my 2cents . I rotated mine last week and it takes a few miles to get the feel back
Old Mar 31, 2004 | 08:47 PM
Ammi's Avatar
350 Detroit Muscle
Rears don't wear out nearly as much as the fronts.
If you didn't notice any pulling before you rotated your tires, I wouldn't worry too much. Probably a tire problem. My car pulls when I put my summer wheels. Doesn't pull w/ my stock wheels.
Old Apr 1, 2004 | 06:25 AM
Kojiro_FtT's Avatar
Drop the clutch and light em' up to try and level out the tire wear
Old Apr 1, 2004 | 08:40 AM
SR20DEN's Avatar
VQ Wizard
http://forums.maxima.org/showthread.php?t=297008
Old Apr 1, 2004 | 10:29 AM
BUDDHAZMAX's Avatar
DAYUMMMM...Sounds like my problem, but i don't have manual, i'ze gots a autolazy
Old Apr 1, 2004 | 10:32 AM
BUDDHAZMAX's Avatar
Oh yeah, about my tires, I don't see any major sign of uneven wear, plus my steering wheel is crooked as well....Hopefully if and when i get 18's or 19's, I won't have the same problem
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
Samedi
Aug 12, 2015 01:54 AM
