Replacing transmission fluid
Old Apr 4, 2004 | 06:59 AM
ldn323's Avatar
Hi,
I have a 2001 Maxima GXE with 43K miles. I am thinking about replacing the auto transmission fluid. A Haynes book for the older model (up to 1998/1999, I think) only mentioned draining and refilling the trans fluid. It does not say anything about cleaning/replacing the filter. Does 5th gen Maxima have a filter for the auto trans? The previous cars that I worked on have a filter that can be cleaned (Saab 9000) or replaced (Toyota Camry).
Thanks.
Old Apr 4, 2004 | 08:51 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Originally Posted by ldn323
Hi,
Thanks.
there is not a fitler per se. there is however a metal screen that can be replaced but most often just needs to be cleaned. if you want to a drain and refill, then just pull the plug and refill through the dipstick what you took out. you should get around 4-5 quarts. if you want to take it a step further, you can drop the pan and get a little more fluid out. while its down, go ahead and clean the magnets in the bottom of the pan. just make sure you have a new gasket for the tranny oil pan. if you decide to clean the screen when the pan is dropped, brake parts cleaner works pretty well.
Old Apr 4, 2004 | 09:10 AM
Jime's Avatar
Flush info is here:
https://maxima.org/forums/4th-generation-maxima-1995-1999/33563-car-died-4.html
Old Apr 4, 2004 | 09:57 AM
Gsilk's Avatar
Reported
is there a filter on a 2k? i went to pepboys yesterday to ask them if they could change it and they said i would have to get the filter from Nissan. they couldnt change it for me because of this......
Old Apr 4, 2004 | 05:27 PM
sloppymax's Avatar
same tranny. there is not a filter, just a screen. you may want to find another shop to take it if they do not know the difference. im not knocking the guys but you may want to take it to place that has a little more experience.
Old Apr 4, 2004 | 07:17 PM
ldn323's Avatar
sloppymax and Jime,
Thank You!
CorollaULEV
30
Aug 9, 2021 08:11 PM
rbuswell
Nov 17, 2016 04:54 AM
maxinout93
Oct 27, 2015 01:29 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
