Wheel spacing question
Old Apr 7, 2004 | 03:39 PM
GeSeKeE19-'s Avatar
I have a 2002 max with 18x7.5 wheels with 42offset. i also have progress springs and kybgr2 struts. I want to space out my rear wheels so that its flush with the fender, but i dont know what size i need. Any opinions?
Old Apr 7, 2004 | 07:37 PM
JoeJoe's Avatar
I've got 15mm in the front and 20mms in the back. Pics on my homepage.
Old Apr 9, 2004 | 09:45 PM
GeSeKeE19-'s Avatar
Would i be able to fit 25mm H&R wheel spacers? Does anybody know if i will rub with these spacers? Also, if i did buy these spacers from H&R, will it come with the new bolts? Is anybody running these 25mm spacers? Your help would be greatly appreciated.
Old Apr 10, 2004 | 02:23 AM
GeSeKeE19-'s Avatar
anybody? Will i rub with 25mm spacers if im dropped on progress springs (a 2 finger gap drop) with 18x7.5 rims with a 42mm offset? currently, i have a 1.25" gap from the tire to the inside part of the fender. i want to push my rim out to almost flush the rear fender well...can somebody give me some advice?
Old Apr 10, 2004 | 06:58 AM
JoeJoe's Avatar
Sorry Man, I'm not sure if it will rub or not. My 20mm seemed close in the rear. And yes, 15mm and up come with new bolts. Good luck.
Old Apr 10, 2004 | 09:16 AM
ZIPPIN's Avatar
Mauja He Mauja
sweet ride..do you not have any rubbing issues??what about with pass in the back?
Old Apr 10, 2004 | 09:37 AM
djPlayboy's Avatar
where do i buy spacers at????
Old Apr 10, 2004 | 12:22 PM
GeSeKeE19-'s Avatar
anybody? You think ill rub? As of right now, tire to inside of fender gap is 31.4mm or 1.25". Im running Progress springs so i have like a 2 finger gap from top of tire to bottom of fender...if i pushed the wheel out with a 25mm spacer, will i have rubbing issues?
Old Apr 10, 2004 | 12:31 PM
Ammi's Avatar
350 Detroit Muscle
Get longer studs w/ your spacers
Old Apr 10, 2004 | 12:44 PM
GeSeKeE19-'s Avatar
uhh...what does getting longer studs have anything to do with my question? I asked if a 25mm spacer will rub...by the way, the 25mm have built in studs on them.
Old Apr 10, 2004 | 01:31 PM
soundmike's Avatar
Very sound, Mike
25mm is approximately an inch. Measure the distance (depth) between where the tire ends and the fender starts. If it's less than an inch then you *might* rub.
Old Apr 10, 2004 | 03:33 PM
Ammi's Avatar
350 Detroit Muscle
I was just warning you that you should get loger studs if you get 25mm spacers. Not all spacers come with built in studs. Post a picture of your spacers if you got them.
Old Apr 10, 2004 | 03:43 PM
GeSeKeE19-'s Avatar
yea, but like i said, the 25mm spacers have new studs built into them. H&R makes an adapter where u just take ur wheel off, put the spacer on, bolt it down and built onto it are new studs where u put ur wheels on and bolt on the wheels. Anyways, anybody running the H&R DRM series spacer?
Old Apr 10, 2004 | 04:10 PM
Triple8Sol's Avatar
I miss the .org!
For your application Geseke, I would suggest 20mm, which means you'll have to use longer studs as well
Old Apr 12, 2004 | 06:21 AM
djPlayboy's Avatar
if i were to get 12.5mm (1/2 in) spacers would i need to get longer studs???
Old Apr 12, 2004 | 08:49 AM
Ammi's Avatar
350 Detroit Muscle
I say if you are using anything thicker than 5mm, get longer studs. Better to be safe than sorry.
Old Apr 13, 2004 | 06:01 AM
djPlayboy's Avatar
where can i get longer studs at, this is my next mod when i get new tires on my 18s
Old Apr 13, 2004 | 06:14 AM
Ammi's Avatar
350 Detroit Muscle
This is one place you can get them
http://www.courtesyparts.com/Merchan...Category_Code=
Old Apr 13, 2004 | 06:24 AM
Chinkzilla's Avatar
This NISMO wheel stud fits all Nissans except the following:
(Z32) 300ZX 1990-1996 - front axle
(S14) 240SX 1995-1998 - front axle
(B13) Sentra 1991-1994 - front and rear axle
(B14) Sentra 1995-1999 - front and rear axle
All Nissans with solid rear axle
That would be us no?
Old Apr 13, 2004 | 06:26 AM
Ammi's Avatar
350 Detroit Muscle
will fit "except" the following Nissans
Old Apr 13, 2004 | 06:49 AM
djPlayboy's Avatar
ouch thats 153.75 for 25 bolts
Old Apr 13, 2004 | 01:19 PM
Ammi's Avatar
350 Detroit Muscle
You only need 20 you know.....
Old Apr 13, 2004 | 02:21 PM
djPlayboy's Avatar
i knew that :P
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
