Coolant Change - Questions
Old Apr 10, 2004 | 05:58 PM
01SE02SER's Avatar
Faster than a speeding bullet...
I wanted to change my engine coolant, but I had some questions:
1) Maybe I'm blind, but where is the Air Relief Plug? For the life of me, I can't seem to find it.
2) In the Electronic Service Manual, it says to remove the drain plugs on both sides of the cylinder block. Over here, however,...
www.motorvate.ca/mvp.php/502
...the person who did the write-up says you can either remove the very-hard-to-get-to drain plugs or don't. Is it okay to just leave those on?
3) If I don't remove the drain plugs, about how much total new coolant will I be adding back (including the reservoir tank)?
Thanks in advance.
Peace.
Old Apr 10, 2004 | 06:45 PM
Mom's2kGLE's Avatar
You must have a haynes maanual because I could not find the air relief valve either. I di not remove the block plug because they're not easy to get to. If I remember right I used arround a gallon and 1/4. I replaced both hoses and I took the tsta housing off and got quite a bit out. The only coolant that isn't out is the heater core and some in the block. Buy 1 gal and mix 50/50 in another bucket and fill,run the car with the rad cap off so you can see the level in rad. Hope this helps.
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
RealityCheck
Aug 5, 2015 06:18 AM
