Upper Strut Mount Noise...
Old Apr 11, 2004 | 12:53 AM
GeSeKeE19-'s Avatar
I just recently installed KybGr2 with Progress springs...anyhow, i noticed a lound grinding noise the other day. I had my brother move the wheel around while i took a look and i found the problem. When turning the wheel side to side when parked, the left upper strut mount (the plastic peice on top of the suspension; aka top hat) turns smoothly without restriction, however my left side, doesnt move smoothly, almost like its getting stuck but it does eventually turn. Anybody know what is wrong or what i can do to fix that? do i need to lube that area?
Old Apr 11, 2004 | 06:41 AM
njmaxseltd's Avatar
Make sure the upper spring perch positioned correctly, the word out should face out.
You strut bearing may need to be regreased or replaced. You can pry the bearing apart easily with a small screw driver, clean it out and apply some Lithium grease, then snap it back together.
Old Apr 11, 2004 | 07:19 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
i replaced both bearing plates and now everything is fine
only problem is i didnt reapply lithium grease
-J
D Mason
Jun 21, 2016 04:43 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
