View Poll Results: Answer ONLY if you truly know: Is 100 OCTANE BAD FOR THE ENGINE?
YES
14.81%
NO
59.26%
I STILL WANT TO VOTE ALTHOUGH I DON'T KNOW.
25.93%
Voters: 27. You may not vote on this poll
Is this bad for the 2k3????
Old Apr 12, 2004 | 11:11 AM
MaximaPolak's Avatar
Is putting in 100 octane bad or good for the engine?
Post ONLY if you know what you are talking about PLEASE!
Old Apr 12, 2004 | 11:19 AM
custommaximaSE's Avatar
How we supose to vote?
The higher the octane the better run the engine.
My vote go for yes as its good for engine.
Old Apr 12, 2004 | 11:20 AM
NT2SHBBY
its not good....hell no...thats race gas...might as well throw airplane gas in there...somethin like 120 octane....
if it was good, it would be sold at the pumps
Old Apr 12, 2004 | 11:21 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Are you talking stock engine condition? If so, it won't really do anything for you, except maybe get you slightly worse gas mileage due to change in burn characteristics of the higher octane fuel. Now if you're boosted, it will help you out because the engine won't have to pull as much timing to compensate for the preignition you normally/usually get when using 91-93 octane fuel. I have no expereince with using 100 octane fuel in this platform, but I have used it in several others that were turbocharged...so I am basing my informed opinions on that information.
Old Apr 12, 2004 | 11:27 AM
My friends put in 100 octane "airplane fuel" from an airport 2 weeks ago and nothing happened to their cars....so this week i decided to try it on my car and nothing went wrong.......I put in like 4 gallons to a more than half full tank of 93 octane.
Old Apr 12, 2004 | 11:28 AM
CCx's Avatar
CCx
Bad? Probably not - grossly unnecessary for your application? Definitely.
Old Apr 12, 2004 | 11:29 AM
NT2SHBBY
just because his car didn't "roll over and die" immediately doesnt mean its not bad for it EVENTUALLY...
but keep using it bro....
Old Apr 12, 2004 | 11:34 AM
OT n00bs FTMFCSL
OK, so it probably raised the total octane rating to like 94.5...which is still a far cry from the 100 octane you posted in your question/poll. And why did they use AVGAS (which contains lead additives). They WILL absolutely regret that later...
Old Apr 12, 2004 | 11:54 AM
Mr. Peabody's Avatar
BAsically,
The higher the octain rating the more compression you can run on your engine without having to worry about pre-ignition otherwise known as detonation which will quickly burn a hold right through your piston.
In answer to the question "if it's so good why don't they sell it everwhere?" The higher the octain rating the more "refined" the gasoline is & thus the more it cost to refine it.
Guess that you boys are just a might too young to remember the old sunnoco pumps where you simply turned the dial to select the octaine rating that you wanted, all the way up to 103! (this is what the 11:1 compression HO engines run). I used to run my bikes on 100.
Running higher octain than your engine needs to prevent pre-ignation does only one thing for you.... it spends more money than you need to.
Mr.P
Old Apr 12, 2004 | 12:18 PM
OT n00bs FTMFCSL
Originally Posted by Mr. Peabody
BAsically,
Mr.P
Wasting money is absolutely correct, by paying more for the fuel, and losing fuel economy b/c the engine will most times not burn the higher grade fuel correctly...
Old Apr 12, 2004 | 01:16 PM
SEDaveMax's Avatar
As long as it's not leaded it will not harm you engine or emisions equip. What some people don't realize is that there are alot of octane boosters out there that put a red coating on your plugs and O2 sensors. At select 76 locations in California they do sell 100 at the pump. San Jose and Stockton are two that I can think of. I say it's good and it will eliminate any detonation (pinging) you might be having from the crappy 91. At least in California
Dave
02 Maxima SE
85 El Camino w/Turbo V6 swap
Old Apr 12, 2004 | 01:18 PM
OT n00bs FTMFCSL
100 octane AVGAS is leaded
Old Apr 12, 2004 | 01:19 PM
SEDaveMax's Avatar
Dave
02 Maxima SE
Oh yeah, would I run it everyday? Hell no! It's over $5.00 per gal last time I checked. I will run 100 only when I go to the track.
Dave
02 Maxima SE
Old Apr 12, 2004 | 01:32 PM
SEDaveMax's Avatar
AVGAS is leaded but the 76 race gas I'm talking about is not. The original post did not specify AVGAS.
Dave
02 Maxima SE
Old Apr 12, 2004 | 01:40 PM
OT n00bs FTMFCSL
I thought he stated it rather plainly myself...
Old Apr 12, 2004 | 02:02 PM
GeSeKeE19-'s Avatar
a friend of mine has a tack car running a completely built engine running a fatty turbo uses 100+ octane....not a street car and he gets the gas at a performance shop...dont know if itll do any good to a stock car, might even harm?
Old Apr 12, 2004 | 02:17 PM
NewLoveI30's Avatar
Its not going to hurt anything, but I dont think it will help either. It just means that you would safely be able to bump compression or advance timing if you had a chip or something.
Its probably useless to run 100 in a stock NA engine.
Old Apr 12, 2004 | 02:19 PM
Fezzik's Avatar
DOnt know if it hurts or not but I know airplane fuel is rated 100LL which is low lead. Dont know if lead is harmful to our engines or not but just letting you know that it does contain lead.
Old Apr 12, 2004 | 03:51 PM
† ErV †
100 octane won't per say ruin anything but airplane fuel will (or a very probably might). no it's not the same as your shell gas since the octane rating is just one thing that differentiates fuel.
Old Apr 12, 2004 | 05:09 PM
itdood's Avatar
Won't hurt the engine but it will smoke the catalytic converter. The lead binds or coats the platinum in the cat and makes it useless. It will affect emission tests, in some cases even start making it fail emissions. Doesn't take much either.
Anyone that puts leaded gas in a cat-equiped car deserves this>
Old Apr 12, 2004 | 05:21 PM
FanaticMadMax's Avatar
How did you friend get ahold of airplane fuel. They are not designed the same as regular fuel that we use in our cars everyday. It's not a bad thing but it can cause a lot of pressure on the parts while will blow apart, perhaps fracture the piston rod. Since higher octane require more engery to denotnate the combustion. So why do you think Aircraft use turbine fan instead of car engine. I would advise against using it if you were putting it in on a regular basis.
Old Apr 12, 2004 | 06:54 PM
SEDaveMax's Avatar
LOL I was talking about the original post NOT his reply 3 or 4 down. You win bro
Old Apr 12, 2004 | 08:16 PM
OT n00bs FTMFCSL
What in the world are you talking about ? I don't know too many piston driven aircraft that have turbines...
I can only guess that you are confusing AVGAS and Jet Fuel (we used JP5 in the Navy). AVGAS is very similar to regular automotive fuel, except that it's usually higher octane and contains lead additives. Jet fuel, on the other hand, is like a mixture of some of the characteristics of diesel and kerosene...
Old Apr 12, 2004 | 10:16 PM
SEDaveMax's Avatar
[QUOTE=Quicksilver]What in the world are you talking about ? I don't know too many piston driven aircraft that have turbines...
The original post (above) said 100 octane. He didn't mention avgas until you asked if he was all stock. I did not read all of the replies before I posted because this was supposed to be a poll. A simple misunderstanding. My bad on not seeing avgas 3 or 4 replies down
Dave
02 Maxima SE
Old Apr 13, 2004 | 05:35 AM
vqman
edit:
I see the jet fuel thing has already been covered...
-vq
Old Apr 13, 2004 | 06:53 AM
OT n00bs FTMFCSL
[QUOTE=SEDaveMax]
Dave
02 Maxima SE
Dave, I wasn't quoting you or directing that towards you. That was in reference to the jet fuel guy...
Old Apr 13, 2004 | 11:55 AM
SEDaveMax's Avatar
Cool,sometimes it's hard to tell just reading words
Dave
02 Maxima SE
Old Apr 13, 2004 | 12:49 PM
brianc's Avatar
Bad for the engine -- probably not.
Bad for the catalytic convertor -- YES!
Congratulations -- You have just dramatically shortened the useful life of your cat.
Old Apr 14, 2004 | 03:42 PM
Tim01MaxSE's Avatar
Yup its not to bad for the motor but say goodbye to the cat and o2 sensors those will be junk
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
