Hhhhhheeeeeeellllllppppppppp...........
Ok, So I Decided To Change My Spark Plugs Today Only To Find Out The My Spark Plugs Arent Burning Right. They Are Not Burning Right In The Sense That There Is Oil In There. Now The Thing Thats Got Me Is The Car Does Not Smoke And Is Nto Low On Oil. So Wtf Is Going On?????????
huh?
-vq
sorry ve been out of it lately, but yea there is burned oil on the spark plugs, what looks to be residue of oil in the bottom, whaere the spark plug goes.
Originally Posted by ABDomega
Please for the love of the Maxima, don't capitalize the first letter of all your words.
It does that automatically when you type in all caps... It changes all of the words to lower case, except for the first letter of each word... which is why you don't see people typing in all caps anymore...
Is the oil on the top of the threads or on the lower portion of the spark plug where it is actually in the combustion chamber?
If you have oil on the top part of the threads, you probably just have leaking grommets on the valve cover. Not too big a deal. You want to take care of it, but it's not a 911 emergency.
If there is oil on the spark plug where it is inside the chamber, the it's probably just excessive blow by from the PCV valve. Did you over fill your oil last time? I seriously doubt that you have a blown head gasket or worn rings. Next time you do an oil change, see if there is gas in the oil. If so, your rings are worn. Do a compression test or leakdown test to verify. Also, check you coolant for any sign of oil or "milkshake". If you have either of the two the blown HG but I haven't heard of one person with a maxima that has blown a HG.
Oh yeah, if it is blow by, just buy a catch can from Summit. They sell cheap ones for $30. You'd be amazed at how much oil actually can accumilate over time. Just think that without the catch can, all that oil would be in your intake manifold and leaving dark crusties inside your combustion chamber. Yuck!
