Removing a 2000 Max Dashboard
I was wondering (since the search feature is down) if someone can tell me how to obtain a detailed document with pictures on how to remove the dashboard on a 2000 Maxima?
Any help you could provide would be helpful.
1- Unscrew 2 screws at the top of the dashboard inside where the instrument cluster is.
2- Unscrew the 4 outside under the steering wheel... that will detach the top part of the plastic cover over the steering column. take that off.
3- Pull out the plastic that is around the instrument cluster that is holding in the gauge cluster into the car... when pulling this out you will have to disconect the wires from behind it. pull out the traction control wire (if you have it) and the other 2 wires on the left side ( i dont remember what they are... i think the dim switch and the mirror adjustment)
4- This will expose 3 screws to remove the actual cluster from the car. 1 on top in the middle, 1 on the bottom left corner, 1 on the bottom right corner. Unscrew these 3 screws
5- pull out the cluster. there are also 2 wires to disconect from the back of this. just pull them out the same way you did with the other ones. once they are disconected just pull the whole cluster out.
6- the clear plastic cover is attached to the cluster with maybe 10 little snaps all around the whole thing... they work on pressure... when you see them you will right away know how to un snap them... just go all the way around and unsnap each of them.
7- once everything is unsnapped just pull the clear plastic off and now your instrument cluster is exposed. stick the guage bezels on each of the gauges. press down firmly and make sure that they stick good... push down all the way around so there are no little cracks that light can pass through between... just run your finger all around a bunch of times applying pressure. also you dont want these things to fly off while you are driving.
8- put the plastic back on and work in reverse order by attaching all the wires and putting the screws back and everything and thats it.
9- sit and admire it and say cool that looks pretty good
I've that on somebody site : can remember who!
I've got pic but on my HD only, email me if you want them!
The Frye
Sep 2, 2021 11:03 AM
lowpost99
Sep 8, 2015 05:06 AM
