Rattle from rear of car, not Bose or Sub related??
Old Apr 20, 2004 | 11:56 AM
PhillyFanCS's Avatar
I have rattle coming from the rear of the car. I have turned the radio off so I know it's not my sub. It only seems to happen when going over bumps but not necessarily large bumps. Trying to figure out if this is just something loose inside or if it could be related to a rear suspension component. I can't pinpoint if it is coming from inside or outside since I haven't had a chance to have someone else drive while I sit in back. Has anyone experienced anything like this??
Old Apr 20, 2004 | 11:57 AM
s_hinerman's Avatar
do you have an rsb i hear they can come lose and rattle
Old Apr 20, 2004 | 12:03 PM
maxguy's Avatar
Try checking out this TSB:
http://maxima.theowensfamily.com/tsb/NTB99-056f.pdf
This has a bunch of rattle fixes in it... i remember seeing something about the fuel pump drop resistor... look at pages 14-21. Let us know if that helps at all... you might even find a way to fix other rattles in there.
maxguy
Old Apr 20, 2004 | 12:07 PM
No I don't have an RSB but was thinking about getting one in a couple of months.
Old Apr 20, 2004 | 12:43 PM
maxguy
Appreciate the help. This will be good info to have on hand.
Old Apr 21, 2004 | 08:04 PM
ckohl23's Avatar
license plate?
Old Apr 22, 2004 | 03:30 AM
redstradic's Avatar
a loose jack thats bouncing around.
Old Apr 22, 2004 | 04:12 AM
maxcosity's Avatar
You won't believe this, but I finally managed to climb in my trunk through the back seat while my wife drove, and I found out my rattle..
The trunk latch mechanism has some parts that swivel and "lock in place" when latched.. This is all metal on metal with a metal pinion to rotate on.
Sure enough, that was it. Furthermore, the trunk latch was so tight it was yanking the latch mechanism really hard when my car was hitting bumps..
I tied a thin piece of dental floss around the pinion so as to take up the space so the metal plate could no longer rattle, and voila -- fixed!!
I still have one small noise -- it's coming from one of my shock towers.. I think something's a little loose from my spring install.. it's nowhere near as loud though..
The trunk latch rattled so loud it sounded as if my car was falling apart.. LOL!
Good luck!! Climb in the back while someone drives, like I did. It will work wonders..
Old Apr 22, 2004 | 01:02 PM
NewLoveI30's Avatar
Nice work on the fix. Ive been trying to find a rattle on the front passenger side.
BTW, if you think your suspension is rattling, you may want to check it out.
Old Apr 22, 2004 | 07:39 PM
maxcosity's Avatar
Yeah, I need to.. I made sure nothing is loose, but I'll get in there and retighten everything real good this weekend again..
Other interior rattles I've found:
* Door light (clear) in lower door panel is loose, hot glue or tape will fix that
* Front seats are bolted into floor, but one of my bolts came loose over time and made noises when I shifted around in my seat sometimes
* Center console below A/C controls where ashtray and lighter go, is very rigid and when it flexes, it makes noise
* Center dash at windshield (behind clock) makes popping sound sometimes on huge bumps (it has gotten loose over time)
* Center armrest clip is slightly loose, but doesn't make too much noise unless you're leaning on it all of the time
* Sunroof shade can rattle, but mine doesn't
* Glove box also can rattle, but mine doesn't
* Loose wires/plugs if you unplugged/removed your Bose HU and left them dangling..
Old Apr 22, 2004 | 07:48 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
yeah my sunroof rattles!! over large bumps....it osunds liek its goign to break off and come on top of me what do i do ??
-J
Old Apr 22, 2004 | 08:29 PM
maxcosity's Avatar
there's a TSB for the sunroof rattle..
as maxguy posted above:
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
Huttig2009
Sep 25, 2015 03:31 PM
doobadoo
Aug 15, 2015 06:43 PM
