clearing out hids this weekend...
Old Apr 20, 2004 | 12:25 PM
trey
and wanted to know if someone to tell me what size bulb to put in there so i can prepare myself? also should i go amber lilke i heard or go with a clear bulb?
any help would be great
Old Apr 20, 2004 | 12:35 PM
s_hinerman's Avatar
go with a chrome bulb that lights up amber. Those look really sharp with clears. Well you can't see them unless they are lit. Do you have the replacement lenses already.
Old Apr 20, 2004 | 12:43 PM
MannyNJ2k2max's Avatar
i left the stocker....its clear and undetectable...and blinks yellow/amber......its easy to change without removing headlight so do your clearing and go from there....you may want to save the few bucks
Old Apr 20, 2004 | 12:51 PM
trey
ohh duh, I was thinking that you can't get to the blinker bulb unless you take it all apart, ahha. thanks guys, i'll just get the clearling out of the way first.
Maybe i should add some blinker fluid while i'm at it.
Old Apr 20, 2004 | 12:54 PM
s_hinerman's Avatar
Definately don't want to let that run low, results could be tragic.
Old Apr 20, 2004 | 12:56 PM
MaximaPolak's Avatar
I too want to attempt this, this weekend. I dunno if i'll go through because I've attempted 3 times already and never opened them....lmao!
and yes, to change the blinker fluid with the royal purple synthetic blinker oil....will make the blinker blink faster.....like a civic...
Old Apr 20, 2004 | 02:04 PM
00MAXIST's Avatar
I have a huge blinker oil stain on my garage floor. I am afraid some of the oil may have gotten on my bumper. Anyone know how to get it off?
Old Apr 20, 2004 | 02:09 PM
2k3TitaniumSe's Avatar
Use the MALIBU flood light lens not, the TAP Plastics.
Old Apr 20, 2004 | 02:40 PM
WildmanAL's Avatar
Did you not leave them in the oven long enought or what? How long did you leave them in and at what temp?
Old Apr 20, 2004 | 02:46 PM
bigdo26's Avatar
I didnt put in new clear lenses when I did mine last week. It matches the high beam and HID low beam "opening" if you will, looks fine to me.
Old Apr 20, 2004 | 02:53 PM
NewLoveI30's Avatar
Use the oven. It works best and is prob. the safest. 250 for like10-15 minutes. They will come apate nicely.
trey:
Stupid question, but is your name Trey? Only reason I ask is that my name is Trey too.
Sorry, I guess I just thought it was interesting
Ummmm... Ill leave now
Old Apr 20, 2004 | 02:55 PM
bigdo26's Avatar
and as for the bulbs, amber colored bulb will reflect amber and it will appear your headlights arent cleared out (discovered that when I did it). Dont get 7440 LED's that burn amber, they're not very bright. I'm getting the chromed bulbs that burn amber this week, those should do the job. Good luck clearing them and dont for get: There are 2 small screws, 1 on the bottom of the headlight, 1 on the side with the blinker, that must be removed before you peel apart the assembly. I didnt see them for a while, couldnt figure out why the headlight wouldnt come apart
Old Apr 20, 2004 | 06:03 PM
trey
ok, i did purchase the tap plastics clear cover, is there anything wrong with it?
My name actually isn't trey, but its kinda my nickname.
Well I hope this project isn't to hard, although i don't see this being a piece of cake either.
Old Apr 20, 2004 | 06:26 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
the malibu lens is the best match to the blinker above it. I don't like how the tap plastics lens looks.
As for those chrome bulbs. I have then in mine and let me tell you, not even half as bright as the oem bulbs. The chrome bulbs are weak. I don't know if they offer them, but i would recommend a nice LED instead of the chrome bulbs. Maybe a 9 LED bulb or something...
Old Apr 20, 2004 | 07:07 PM
housecor's Avatar
But they're bright enough IMHO. I doubt an LED would do much more. Maybe you could try using a little silver paint on an amber bulb as a brigher alternative. Also, as you can see in the sig, the chrome bulb keeps the lens looking clear.
Old Apr 20, 2004 | 10:47 PM
thomasd cook's Avatar
You will need a soldering iron when installing the tap plastic lens. When you remove the orange lens you will see that if you try to put the new lens in it will not sit flush. This is where the soldering iron comes in. Heat it up and you'll notice that right where the new lens lines up there are 2 little chrome looking nubs that won't allow the lens to sit flat. I burned the nubs off and it sits perfectly.
Old Apr 21, 2004 | 04:23 AM
Lumbee1's Avatar
Latest advances in blinker fluid, GELS!
GELS: A BETTER SOLUTION
Replacing optical fluids with noncuring optical (NCO) gels overcomes the problems of dimming blinker fluid. These gels combine optical-quality synthetic fluids with insoluble microscopic powders, both precisely formulated to yield a specific index of refraction. The gels' consistencies are similar to petroleum jelly, but the similarity ends there. NCO gels are clear and clean. They possess high optical clarity and absorption losses of less than 0.0005%[mu]m of path length in the splice. And they are ultrafiltered to contain no particles larger than 34 [mu]m, nor more than 300 particles larger than 1 [mu]m/[cm.sup.3], standards originally developed for spacecraft lubricants.
NCO gels have shear-dependent viscosities. They have a measurable viscosity, but when they move, they become more fluid-like. This means gels can be pumped into small assemblies. Once in place in the splice and the shear rate goes to zero, NCO gels behave like an elastic solid and stay in place indefinitely. They are chemically stable from -40[degrees] to above 200[degrees]C, have evaporation rates of less than 0.1% (ASTM D-972, 24 hr @ 100[degrees]C), and will soon become the industry standard for blinker fluid in new cars.
Old Apr 21, 2004 | 06:50 AM
nissan5788's Avatar
Trey, it's not hard at all, just make sure you follow the instructions Housecor has and you'll be fine. I've opened up mine twice, very easy to do if you take your time.
I like the Malibu lens better also, matches perfectly..but you already bought from Tap so it's not really worth it to not use them, and buy the $7/piece Malibu ones.
Old Apr 21, 2004 | 07:57 AM
I haven't tried the oven yet cause i'm a bit afraid to do that.....anyway i'll try it this weekend.
Old Apr 21, 2004 | 08:45 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I used the oven 220 degrees for about 15 minutes. They opened fine. I used the Malibu lens.
bigdo26 - I had 3 small screws in mine. You're right, they won't come apart if you don't remove them!
All in all, it was easier than I thought it would be, but I was nervous when starting it. It went very well, though. Mine sealed back up very well - no condensation or leaks. I had to warm them up in the oven before sealing them back up.
I followed housecor's how-to. It is very good.
Old Apr 21, 2004 | 09:37 AM
housecor's Avatar
Not to go OT, but nissan5788 - That sig pic is slick. Never seen your car. Great looking Max! I love that blue.
Old Apr 21, 2004 | 01:11 PM
trey
Ok one more question, in housecor's directions/pictures, it shows the whole headlight assembly in the oven, why not just put the piece with the amber lense and other lense in the oven?
It shows the two lenses by themselves in one of the pictures, so why the whole assembly?
by the way, thanks a lot to all of you, great info.
Old Apr 21, 2004 | 02:01 PM
housecor's Avatar
The lens you're clearing is inside the headlight. Therefore, you need to heat the headlight in order to open it up to get to the lens. Please tell me you're kidding with this question! :
Old Apr 21, 2004 | 03:15 PM
trey
Umm yeah i was kidding..... I was thinking you have to heat up the assembly to get the amber lense out. I think i got it now.
Old Apr 21, 2004 | 05:17 PM
nissan5788's Avatar
Thanks housecor...yeh, finally got a chance to take pics of the ride after a wash/wax
You've got a nice ride yourself..great site as well, very helpful!
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Vistance
Sep 17, 2015 05:17 AM
