hardware for the 5th gen rear sway bar
Apr 22, 2004 | 01:41 PM
i bought the rear sway bar from custommaxima about 2 years ago and i havent had time to install it ....long story....anyway i tried to do it the other day and i noticed that the threads on the u-bolts do go high enough on the bracket.. it stops midway and just dangles there ... did i get the wrong hardware or am i doing something wrong here.. even the little bolts on the side dont seem to fit... if i did get the wrong hardware can i get these pieces from any home depot or am i stuck with a sway bar i cant use.... do u think if i go to a performance shop they can install it without using 1 million washers?
thankts for the input
Apr 22, 2004 | 06:18 PM
you can get the hardware from home depot. just bring in your u bolts to see if they have the same bend radius for them, and you can get a longer length. as for the hardware on the side, well, I recently installed my progress sway bar and I think the bolts were either 5/16 or 3/8 x 1.25 or 1.5".
that means, the diameter is 5/16 or 3/8 and the length from the head of the bolt is either 1.25 or 1.5. I forget, but it is either of those sizes. just measure the diameter of the brackets and see what will fit in there, and you should be good to go
Apr 22, 2004 | 06:36 PM
wut i did was i called addco...very nice guys and they were kind enough to send me new set of hardwares for free
Apr 22, 2004 | 07:18 PM
or you could do that as well
Apr 23, 2004 | 11:45 AM
thanks for your help guyd. i appreciate it. im gonna call them and if that doesnt solve anything im gonna go to home depot and see if i can get the brackets there
