Dynoed Yesterday
Old Apr 25, 2004 | 07:05 AM
MaximaSe2002's Avatar
Dynoed Yesterday
well i finally got my car dynoed and i'm not sure i'm happy with the results without the cattman y-pipe but with the jwt pop charger and my own custom b-pipe as well as the cattman muffler i put down 210hp and 221tq now with the y installed i put down 212hp and 218tq this was on 2 different dyno both were dynojets and my car is an auto is this low for my mods?
Old Apr 25, 2004 | 07:55 AM
PhxBlue's Avatar
MK3 Supra and Focus ST
No, that sounds about right.
Old Apr 25, 2004 | 08:03 AM
2k3TitaniumSe's Avatar
Your numbers are pretty much what I would expect for an auto.
Old Apr 25, 2004 | 08:52 AM
juice's Avatar
Those numbers sound about... right were those SAE corrected or STD corrected number?
Old Apr 25, 2004 | 08:53 AM
sascuderi's Avatar
What kind of numbers would you have expected without any mods?
Old Apr 25, 2004 | 09:13 AM
Virus's Avatar
Exactly where I'm at with the same mods with exception of the muffler.
Old Apr 25, 2004 | 09:18 AM
TOMBGUARD's Avatar
Sheet is in my registry.
Yesterday I dynoed 244hp and 243TQ on my 3rd gear pull
And 243HP and 244TQ on my 4th gear pull.
Pics of sheet in my registry
Old Apr 25, 2004 | 10:10 AM
there was another guy there with stock se 6 speed put down 201hp...but the thing that gets me is that with the y i gained 2 horse and losses tq
Old Apr 25, 2004 | 10:45 AM
03BlkSETE's Avatar
If I'm reading it correctly the runs were done on different dyno's so that make the comparison a little more difficult.
Old Apr 25, 2004 | 01:07 PM
bgates1654's Avatar
Not only that but we have no idea what type of correction was used. You are going to have to give us a little more info if you want us to help you out.
Old Apr 25, 2004 | 02:31 PM
ok it was sae corected as yes it was done on two different dyno's....what else do you need to know?
Old Apr 25, 2004 | 02:42 PM
looslip's Avatar
Horra!!
I would say that your numbers are pretty good. I'm an auto w/ FC intake and Cattman Y and I'm only getting 206hp/216tq.
Should I expect those numbers if I get a catback then or is my car just different?
Old Apr 25, 2004 | 04:04 PM
bgates1654's Avatar
Were both SAE corrected or just the second one? Could you please post both dyno graphs?
Old Apr 25, 2004 | 04:43 PM
02MaximizedVQ's Avatar
Do you have the stock cat? If so get rid of it with a test pipe. What size pipe did you get to run between your b-pipe and muffler? What diameter is your B-pipe?
Old Apr 25, 2004 | 05:33 PM
both dyno's were sae and the b-pipe is 2.5in outside diameter...i'm still running the stock cat...i'll try to find the first graph and post them tomorrow although i don't have a scanner i'll try to get to my parents house and use theirs
Old Apr 26, 2004 | 09:14 AM
Cattman's Avatar
Maxima.org Sponsor
There's nothing precise about dyno runs, especially between different machines and different correction factors (these things aren't consistent, because the SAE corrections cannot take into account the extent that a given model's ECU is compensating for changes in temperature or atmospheric pressure). The dyno applies the same corrections, whether the car has a carburator and no ability to compensate for these variables, or ECU-driven FI that is programmed to accomodate changes in altitude, temperature, etc.
So, I won't quibble with your results except to say that the figures you're quoting - max hp and tq - don't really tell you much. Difference in peaks tells you almost nothing, its the margin of the after run over the before run, across the rpm band, that matters. Tell me what the average hp and tq difference was between 3500 and 6500 rpm - those are useful numbers. For example, if peak numbers showed zero change, but the performance part holds a 15-20hp advantage over the stock part out to redline, it would be a success but someone else would say, "hey, its worthless, look at the peaks."
How do you get those numbers? Always tell them you'll need the tabular data from the run (columns of #s) before you get started. That way, if they're totally clueless about generating anything but a simplistic graph, you can go on to a dyno shop that knows what they're doing. Once you have the #s, pour them into Excel and do some basic spreadsheet analysis to get a real thorough understanding of the results.
I'll also add that the 02/03 Cattman y-pipe has been dyno tested extensively, not only the independent testing that we had done on the prototype, but by several customers. Their "peaks" are significantly higher than your results, but most importantly, the tests show large and consistent power margins over the stock part - low to high rpm, across the board.
Brian C Catts
Cattman Performance
Old Apr 26, 2004 | 10:03 AM
bgates1654's Avatar
Hey Brian, could you point me in the right direction to find the independant dynos you speak of? I have been considering your y-pipe for a while but havent seen any good reliable data to solidify my choice.
Old Apr 26, 2004 | 10:30 AM
Cattman's Avatar
Maxima.org Sponsor
Sure, no need for a lack of data to hold you back. Send me email and I'll be glad to reply with dyno spreadsheets and graphs later today (I've got some errands to run first).
Brian C Catts
Cattman Performance
Old Apr 26, 2004 | 10:50 AM
F23A4's Avatar
I saw Brian's dyno sheets with the Y-Pipe and Y/B-pipe combo. I'm VERY impressed.
MaximaSe2002, why dont you post the entire dyno sheet??
Old Apr 26, 2004 | 10:53 AM
so what may cause the other customers # to be so much higher than mine? were they manual or auto? the only info i have is the gragh they give you and i won't be able to post it up today.
Old Apr 26, 2004 | 11:05 AM
AcidReflex's Avatar
I know im the stupid person asking the stupid questions but, what happened to the stock 255 hp?
I guess they didn't mean 255 whp.
Peace
Old Apr 26, 2004 | 11:11 AM
PhxBlue's Avatar
The 255 is the HP at the crank.
Old Apr 27, 2004 | 10:50 AM
ok here is my dyno sheet don't know if you can read it cause i took a picture of it but here it is
http://photos.yahoo.com/serspecv2002
Old Apr 27, 2004 | 11:56 AM
bgates1654's Avatar
I didnt see a picture of a dyno sheet in there.
Old Apr 27, 2004 | 11:57 AM
03BlkSETE's Avatar
Can't seem to find it. Which album is it in?
Old Apr 27, 2004 | 03:24 PM
sorry about that guys forgot to make it public
Old Apr 27, 2004 | 03:43 PM
TOMBGUARD's Avatar
juice, what does STD corrected mean?
Old Apr 27, 2004 | 06:41 PM
bgates1654's Avatar
STD is a correction factor like SAE. STD is a bit more generous than SAE is. For example I recently dynoed at:
227.4whp 243.3wtq STD
When converted into SAE via dynojet's runviewer it returned:
223.0whp/237.2wtq SAE
Well to tell you the truth even if you posted the two dynos and they were legible you couldnt really compare them anyway. Using two different dynos makes it pretty much incomparable. If you really want to know what gains you got with the y-pipe go back to the dyno that you got the baseline from and do it again.
tarun900
19
Dec 20, 2021 06:57 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Junebug1701
Sep 25, 2015 01:54 PM
foodmanry
Sep 24, 2015 12:02 PM
