Pics of LED's in Speedo finally up.
Old Apr 30, 2004 | 10:58 AM
  #41
custommaximaSE's Avatar
Originally Posted by thomasd cook
Is the brightness correct 1,100? That's not too bright. But if that is correct I'll start looking for the LED's with that luminescence.
If you want cheap leds go here:http://www.hosfelt.com/
And what happen you did not PM?
Old Apr 30, 2004 | 10:11 PM
  #42
thomasd cook's Avatar
Originally Posted by maximaman777
Maybe it's the camera, it's one pic hard to judge, but what I'm talking about is in the pic posted there are many areas in the cluster that are whiter than blue or a darker shade of blue. These are mainly in the gas, speedo, tach & temp gauges.
I'm not going to try and steal any of your thunder I'd just like to do this myself. I like to tinker and this is relatively inexpensive. I haven't done any of the leds in the car yet and I want to make sure I get something that matches all around when I buy the leds.
This is great info for me to go buy. Anything else you can post or pm on the job would be great. I'm going to do the climate control as well. If I get it done before you I'll forward what I learn to you. Also we need to figure out how to do the needles too.
Thanks,
Adam
I'm telling you that in the picture it looks like it is spotty. There are more pics of it on my homepage. In front of my face it does not appear that way. It is a solid blue. I posted before that the only thing not too bright is the needles due to the orange. I have some clear and black needles and hooked them to my spare speedo and it looked very nice. I'm scared that if I mess with the needles that they'll never be the same. The speedo instructions worked on calibrating the needles but I couldn't remove them very easily.
I also hooked up a blacklight LED in my climate control and it worked. As soon as I get some more LED's in I'll finish that up. At least I know how to do it. That's an extreme PIA to do these three bulbs. No way of using the holders on these. the LED must be solderd directly on to the board with the resistor.
Also CustomMaxima I sent you a reply. Are you sure you want 1,100 MCD LEd's that's not too bright but if that's the exact # you want I'll order the LED's. How many do you want. Just the speedo, which is 4?
Old May 2, 2004 | 05:48 AM
  #43
MaximaMan77's Avatar
Could you tell me what size the original LEDs were in the speedo, Climate Control & anything else in the dash you've done were. I'm going to use the same size as original and I noticed after looking at the ones in my doors in my 2k2 the rears are 3mm and the 7 in the front are smd LEDs. I'm going to use lower 250-500 mcd LEDs in the doors because all I can find are 250 mcd smd's so to match I'll do the same for the 3mm in the rear and use the stock rubber holders with 1/8w resistors for them.
If you're going to supply these for people you may want to try it this way. It'll be a lot easier to bend the leads through the rubber piece than all the cutting and soldering you did on yours. I wish my fronts were like this too, it would make the job much quicker. If you still have those rubber pieces you can do these for others as you have something to start with.
I ordered a bezel for the speedo along with a dash kit for my M/T 2k2 from Custom Maxima today so I can do it all at once. But I'd like to make sure I order the right LED's and resistors for it at the same time.
Thanks for the info and help.
Old May 2, 2004 | 08:22 AM
  #44
First there are no LED's in the speedo it's little light bulbs. And the same for the climate control. The speedo and climate control are completely different. And if you go with such a low mcd on the LED's, they won't be much brighter than stock. I know my main reason for doing this is because I want them brighter and a different color. I've got my method of doing these, it took me a while to figure it out and I'm sticking with it. It doesn't take me too long to do it now that I've done it so many times. You have your own way, then do it. There aren't too many ways of doing this because it's so small.
Old May 2, 2004 | 10:58 AM
  #45
The low mcd is for the doors not the speedo,
I definitely plan on using something in the 4-6k range there.
Thanks for the info.
mvm062
Nov 30, 2020 09:00 AM
doctorpullit
Jul 20, 2019 09:31 PM
Pixel
Sep 15, 2015 05:53 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
