ECU code 0201 - ignition signal primary circuit fault - need help!
Old Apr 26, 2004 | 07:13 AM
super6's Avatar
i got my ECU read and ended up with two error codes:
0608 - cylider one misfire
i was going to change the spark plugs this week anyway, but will i have to change cylider one coil as well?
and the second signal "ignition signal primary circuit fault" i have no idea what that means. what do i do to fix it? thanx!
Old Apr 26, 2004 | 07:37 AM
MIXXMAX's Avatar
Yes, the ignition signal primary circuit fault is a coil problem. It's a common problem with the '00 models. I had all mine replaced a couple of weeks ago. It may be one that is bad or more than one. Might want to test each one to see which ones are bad. I hope this helped you out.
Old Apr 26, 2004 | 08:04 AM
super6's Avatar
how do you test the coils?
im thinking the bad one must be the number one, same as the plug, maybe the plug isnt working because of the coil.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
220k+ A32
Sep 22, 2015 03:08 PM
Steven Orozco
Sep 12, 2015 10:41 PM
