OEM keyless remotes
Old Apr 28, 2004 | 06:53 AM
maxima105's Avatar
OEM keyless remotes
I just bought an 03 Maxima and I need another Keyless Remote. I have seen a lot of keyless remotes on ebay for $10 or $15. Are these keyless remotes on ebay legit? Is there anything that I should be on the look out for?
Old Apr 28, 2004 | 06:57 AM
Progress's Avatar
It's business time.
I don't know about those remotes, but I do know you will have to get them programmed at a dealer. That is where the cost is high.
Old Apr 28, 2004 | 06:58 AM
takkar's Avatar
I guess you can use them if your FCC-ID match...I am in canada and mine are different than the ones i see on different sites. I bought my car 2nd hand and it came with only one remote
Old Apr 28, 2004 | 07:53 AM
maxima105's Avatar
Where do I find the FCC-ID? According to the people selling these on ebay they come with instructions on programming them. Are these easy to program like the 4 Gen maxima's?
Old Apr 28, 2004 | 07:57 AM
schernov's Avatar
www.chipkeys.com
I bought a key and remote from there and had the key/fob programmed at the dealer for $40
If you need to program just the fob, you can do it yoruself for free!
http://www.courtesyparts.com/Merchan...ntry_Instr.gif
Old Apr 28, 2004 | 08:11 AM
takkar's Avatar
FCC-ID is written behind the remote.
Old Apr 28, 2004 | 11:44 AM
maxima105's Avatar
Thanks for the info....
Old Apr 28, 2004 | 07:02 PM
Maxpat82's Avatar
The remote can be easily program by yourself but not the key!
Remote = 5-10 min max to program here.s how:
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
Done this on my friend 1997 and just work fine!
Old Apr 28, 2004 | 07:27 PM
2k3TEMaxSE's Avatar
Remote For Sale
I have a remote for sale - brand new - never used from my totalled 03 maxima - remote should work with any Altima/Maxima & all infiniti i believe from 2002 model year & up - as long as FCC ID matches - then it's all good
If you want - i'm selling it for $20 + $1 shipping to US
E-mail me (pillpusher84@comcast.net) if interested
--Antonio
Old Apr 29, 2004 | 02:31 PM
bobby.cim's Avatar
I bought one off of Ebay. It came with instructions and works perfectly fine. I would reccomend doing that then buying one at the dealer. The only thing you might not like is that it is used but still looks fine.
Old Apr 29, 2004 | 03:10 PM
unrealii's Avatar
fyi, autozone sells oem remotes.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
