Which springs with stock struts: Max H tech Prog
Old Apr 28, 2004 | 03:03 PM
Shift_VQ's Avatar
I need to get rid of the wheel gap but Im saving for summertime 20s so money is tight. Which spring is the best to run with stock SE shocks/struts for about a year until I upgrade to gr-2s Maxspeed, H-tech, or Progress, also I want a level drop that wont rub with 20x8.5 Diablo Lionharts...not sure of the offset. I also have two 12's in the trunk so the rear is wayed down about 75 lbs.
Thanks in advance for the advice.
Old Apr 28, 2004 | 05:26 PM
housecor's Avatar
H&R - You'll want the least extreme drop to make your stockers last as long as possible. Also, with 20's, the ride will be much stiffer - the H&R's offer the best ride of aftermarket springs.
More info: http://www.innerbean.com/housecor/sp..._decision.html
Old Apr 28, 2004 | 11:20 PM
Shift_VQ's Avatar
But H&R's make the maxes rear sag.
Old Apr 29, 2004 | 03:19 AM
redstradic's Avatar
i would go with the H-techs. I have those paired with the GR2s and its a nice ride. Plus, with your subs, it will make the drop more even since the springs lower the front a tad more than the rear.
Old Apr 29, 2004 | 06:03 AM
Shift_VQ's Avatar
do you have any pics of your setup?
Old Apr 29, 2004 | 06:08 AM
housecor's Avatar
Pics of multiple setups here: http://www.innerbean.com/housecor/sp..._decision.html
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Justin Kroll
Sep 2, 2015 11:06 AM
