How tos? HOTSHOT header?
Old Apr 29, 2004 | 11:29 AM
kpby911's Avatar
Does anyone know where i can get information on installing the hotshot headers on 03s? i just found out today that u have to drill holes for the O2 sensors.. any info would be appreciated.
Old Apr 29, 2004 | 01:14 PM
Larrio's Avatar
The Definitive AE Master
this is not exactly a task for people that aren't incredibly mechanically inclined.
you don't have to drill holes. You have to weld two o2 bungs for the secondary o2's after the main cat
Old Apr 29, 2004 | 01:35 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
first thing is first...your hands must be made of titanium!!!!!
Old Apr 29, 2004 | 01:49 PM
kpby911's Avatar
did u weld the bung ur self? looks like the bungs were aready set on ur headers.. how long did it take u to install ur headers? thanks!
Old Apr 29, 2004 | 04:12 PM
Larrio's Avatar
there are two bungs already on the headers for the primary o2s
another two will have to be welded after the cat for the secondaries.
Old Apr 29, 2004 | 05:08 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Or.... U can leave the bungs out, get some 02 sensor eliminators and let the 02s hang somewhere where they won't touch anything or get destroyed- mine sits under the cover on the valve cover. The eliminator is basically a resistor that fools the computer into thinking the cats are working. If U have a cat- then it will be fine, if U don't have a cat then the 02 sensor eliminator is needed eighter way- I used to get Check engine lights every 4 days with my style of driving cause of no Cats.
Old Apr 29, 2004 | 05:11 PM
BTW install is pretty simple- takes about 2 hours with a lift and tools see the attached pic below... hmmmmm tooools <HommerSimpson>
Old Apr 29, 2004 | 06:22 PM
Larrio's Avatar
and the key word: "with a lift" .... heh.
my mechanic did another car in 6 hours, taking his time without a lift and also taking out the radiator.
Old Apr 30, 2004 | 04:01 AM
Martin F.'s Avatar
were do you get the 02 eliminator?
Old Apr 30, 2004 | 05:42 AM
Jime's Avatar
Here is the one I am using. Get the dual output for your 03.
http://www.o2simulator.com/
Old Apr 30, 2004 | 09:25 AM
MyownNismo's Avatar
Future Camaro SS owner
This wouldn't be the same on a 2000 fed would it. I am trying to see if I can put them on my car. looking at the headers they got a O2 sensor at each header. Mine only has three O2's right one on each manifold and after the main cat.
Old Apr 30, 2004 | 09:31 AM
Jime's Avatar
With that you won't have to do any relocating at all just plug in the two that were on your stock manifold into the headers and leave the other where it is.
The problem with the 3.5's is that there are 2 before the precats and 2 after on the stock manifold so the 2 rear ones have to be relocated after the main cat after the precats are removed.
Old Apr 30, 2004 | 09:49 AM
MyownNismo's Avatar
ok thanks for clearing up.
Old Apr 30, 2004 | 12:18 PM
ajsince81's Avatar
has anybody done a write-up on how to install the headers on the 3.5L.
Old Apr 30, 2004 | 12:32 PM
Mick Max's Avatar
Wild at Hurt
While on the subject if no one minds, with the stock exhaust, how much does the noise level go up?
Old Apr 30, 2004 | 03:33 PM
03BlkSETE's Avatar
Mick, the guys with headers and stock exhaust have reported that the sound level is very tolerable and actually quite nice sounding...350z ish. My setup on the other hand is pretty loud.
Old May 1, 2004 | 06:52 AM
kpby911's Avatar
thats what im wondering..
Old May 1, 2004 | 08:54 AM
Larrio's Avatar
and with all the posts going on asking for header how-tos there obviously isn't one.
not something every person is willing to do, taking pictures while taking about the car and various components for a 4-6 hour installation. not enough ppl are running headers (15+?) on the board yet.
Old May 2, 2004 | 12:03 PM
kpby911's Avatar
im still don't know if i should install it myself or go to the shop and pay $400 to install the dam thing..
Old May 2, 2004 | 04:13 PM
ajsince81's Avatar
Is there any negetive effect on using o2 eliminators on a 2002? Could it be harmful to the car at all?
Old May 2, 2004 | 04:23 PM
Jime's Avatar
All they do is send a signal to the ecu that the cats are performing, they have absolutely no function other than that. All the controlling is done by the primary o2 sensors the secondaries do diddly.
If you don't care about the light being on then don't waste your $25 on the eliminator.
I want to know if the cel is on and why so I chose to use the o2 eliminators.
Old May 3, 2004 | 06:01 PM
ajsince81's Avatar
who sells the hotshot headers for $550
Old May 3, 2004 | 06:41 PM
Jime's Avatar
SWA had them, thats where I got mine, but the price is higher now, HS has increased their prices.
$579 shipped now.
Old May 3, 2004 | 07:14 PM
I'm ordering mine up this Friday
Old May 3, 2004 | 07:16 PM
BTW I done a write up on how to install headers on the 5th gen forum here.... like a week ago or so.
Old May 4, 2004 | 04:44 AM
TOMBGUARD's Avatar
Ours comes with the bungs already in the pipe. All we have to do is install.
Old May 4, 2004 | 06:42 AM
Colonel's Avatar
Old Fuddy Duddy
Hmmm, I might be interested in having you do these for me...but not until you report back if it was worth while to put them on a 3.0. I think you are the first...right?
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
ac max 92
Sep 17, 2015 07:35 AM
Maxboy23
Sep 4, 2015 06:04 PM
