good cams, pistons, heads, etc.
Old May 2, 2004 | 03:22 PM
NJ02maximaGLE's Avatar
looking to do some engine work and I am wondering which makers I should go with for:
Cam shaft(s)
heads
high compression pistons
ignition system
spark plugs
injectors
Thanks alot
Mike
Old May 2, 2004 | 05:03 PM
MAXINXS's Avatar
Go here: http://store.yahoo.com/sgpracing-store/index.html
Old May 2, 2004 | 06:16 PM
Larrio's Avatar
The Definitive AE Master
i doubt you'll max out the stock injectors going all motor on your maxima. I'd invest in the high comp. pistons, rods, titanium valves, and camshaft
Cam shaft(s)
heads
ignition system
spark plugs
injectors
Thanks alot
Mike
Old May 2, 2004 | 07:30 PM
Ghase's Avatar
Cam shaft(s)
heads
ignition system
spark plugs
injectors
This ain't no Honda, parts ain't Cheap.!!!!!! Stuff like that is going to $$$. Some of that stuff mite even have to be custom made!!!!!!!!!! It'll be sweet if you can do it though!!!!!!!!!!
Old May 3, 2004 | 02:58 AM
Triple8Sol's Avatar
I miss the .org!
It's all available from several companies, but have yet to see it on a Max...
Hell, Nismo even makes a crank too...
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
