ses/cel/mil 1448?
Old May 3, 2004 | 09:14 AM
wpm's Avatar
wpm
ses/cel/mil 1448?
ses light on 2002 SE with 56K
O'Rielly auto parts store loaned scanner (autoxray)
0455 evap system gross leak (gas cap tight)
and 1448???
Any one know what this code is?
thanks
Pat
Old May 3, 2004 | 02:13 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
and 1448???
thanks
Pat
P1448-EVAP canister vent control valve open. edit- i do not have any experience with this code so maybe someone else will be of assistance.
Old May 3, 2004 | 08:09 PM
elchino's Avatar
This code is a mess. I've pulled up the instructions on how to diagnose it and it's quite long. Basically there are about 18 possible causes for code 0455 and you would have to go through the process of elimination to weed through them. The instructions say troubleshoot 1448 first. 21 pages of instructions all in all.
Some members might have luck with cleaning out some hoses or the vent valve, but I'm just too lazy. I'm going to the dealer with mine.
How bad has your mileage dropped? I've lost about 5 MPG city.
Old May 4, 2004 | 04:58 AM
wpm's Avatar
wpm
milage
Problem is intermittent. Possibly vent valve not closing reliably?
I have not noticed mpg suffering yet. Does anyone know where the vent is located so I could clean it. I hate to waste a day going to the Dealer and hassel with extended warranty with something I could cheaply fix.
Old May 4, 2004 | 11:42 AM
dinlong's Avatar
actually your best bet for this combination of codes would be to simply clear the dtc memory and drive the car a little bit.
P0455 - evap gross leak - usually a loose gas cap
P1448 - vent control valve - sometime a vent valve
the vent valve code can actually pop up in relation to the gas cap code. as a 2002 your car is equipped with the new style vent valve which is much less prone to failure than past designs have been (although they can occasionally go bad)
if it were me: i'd clear it and drive - if it comes back, just replace it (not a big job by any means)
Puppetmaster
144
Feb 21, 2016 09:40 AM
Bronxboi5
Sep 22, 2014 06:54 AM
ozzombie13
Dec 17, 2007 09:16 AM
Cdg2125
Jun 28, 2007 09:02 PM
