Climate control light
If ur talking about the climate control lights i had 3 burn out within a week, after i got my new head unit installed, Part number for those bulbs
27545-1w600 ITs blue blulb, well it has a blue cover. Umm i had to figure it out a bit, took out the frame that held the headunit and the climate controls , had to remove the center conosle piece where shifter is, took complete frame out and then had to take some little screws out of the climate control. then u pop out the snaps that hold the climate control in place from the back side plastic and u 'll reach the green circuit board. the bulbs are screwd on it, turn on lights to see which is burned and then turn them off and unscrew with fingers. kinda like taking out ur blinker lights. Its a bit of looking at it, having patience and figuring out how things come out. Hope this helps some, its not easy to explain but i figured it out on my own. Oh it takes couple days to get bulb in, they don't usually stock it, i paid 5.94 per bulb plus tax. I did use the blue rubber that covered the burnt out bulbs and slipped it on the glove box and cigaret ligther bulb. It served a purpose now i got blue lights for those.. Make good use of the burnt bulb if u want. Good luck..
MikesChevelle
Mar 2, 2021 11:32 AM
asianstyle
Aug 24, 2015 08:29 PM
