Power window safety feature adjustment
Old May 5, 2004 | 04:03 PM
XGaSpAcHo
I have a problem with my front passenger side power window. When I close it using Auto it goes all the way up and then comes down about 3 inches. But it closes all the way and stays shut when I do it manualy. I've figured out that this is because the feature which prevents someone's hand or neck getting caught by the window needs to be adjusted. The dealer says that adjustments are only covered for the first 12 months and wants to charge me to fix it. Does anyone know how to go about fixing this? Thanks in advance.
Old May 6, 2004 | 12:07 PM
swapmeetlouie's Avatar
bump bump bump bump it up!
Old May 6, 2004 | 12:11 PM
slickrick's Avatar
maybe something is in the way of the window or the connection in the door is loose.
Old May 8, 2004 | 08:06 AM
XGaSpAcHo
No there is nothing lose everything works fine from what I understand the sensor just needs to be adjusted. Anybody have any ideas?
Old May 8, 2004 | 09:13 AM
Zero Deuce SE's Avatar
Your dealer is blowing smoke. That should be covered under the 36 months 36K miles warranty. Try another dealer if possible.
