Who went from Tein S Tech/KYB GR2 setup to a Tein/Illumina setup?
Old Jul 27, 2004 | 09:22 PM
  #41
panda_1's Avatar
speaking of struts and you guys doing it all over again, which is similar to my situation should i just save up extra and go with the illuminas?
Old Jul 27, 2004 | 09:47 PM
  #42
MetaOrbit's Avatar
Got Projectors?
Trust me...save up and spend the extra cash on the Illuminas. You'll be happy that you did.
Old Jul 28, 2004 | 02:25 AM
  #43
maximadave's Avatar
detailerdaveb@gmail.com
Originally Posted by Triple8Sol
So maximadave, what I really want to know, is if the Illuminas eliminate the "ricer" bounce that your car gets. (Just like metaorbit describes...we've discussed this before...lol)
after today I'm at 4f/5r and to me IMO its perfect. The bumpstops are cut (I dunno how much) and the spring does not bottom out like it did before. No ricer bounce at all.....lol
Old Jul 28, 2004 | 05:29 AM
  #44
kirzan's Avatar
Originally Posted by gsumax
i believe you can, im pretty sure albert did (rob van dam) you can pm him and ask him what he exactly did...
Definitely like some more info on this. I don't mind taking the strut assembly off the car, but I'd really like to avoid compressing the whole mess again by hand.
Old Jul 28, 2004 | 01:01 PM
  #45
jaco's Avatar
kirzan, i don't think you can cut bumpstops while the spring is on. the ruber is very thick so cutting it to take it off the strut would be quite difficult.
when this happened to me, i did not even have to use spring compressor to take tein-s off. instead, i put a bit of force with my hand and that did the job. total time it took me was about 5 min per shock.
Old Jul 28, 2004 | 01:56 PM
  #46
kirzan's Avatar
Okay, so you took the strut and spring off the car and were able to compress it by hand? Doh! Definitely could not do that with the Maxspeeds. If I took the hat bolt off without compression, the spring would go flying across the garage. I was thinking maybe I could do it it with a dremel once I've removed the strut from the car. Maybe not ...
Old Jul 28, 2004 | 02:08 PM
  #47
NewLoveI30's Avatar
The Illuminas are killer struts... Period!
BTW, I have Eibachs/Illuminas and did not trim the bump stops. I have them set to 5/5 and very rarely is the ride uncomfortable. It gets a little anoying in LA with their $hitty hwys, but its uncomfortable in most cars too.
No more slop, but it wont rattle your teeth out either.
Old Jul 28, 2004 | 02:20 PM
  #48
purekoryo's Avatar
would leaving the bump stop as is hurt anything?
Old Jul 28, 2004 | 02:48 PM
  #49
Bl_asd's Avatar
..if i got JIC..do i need any spring or strut? it looks like JIC has both set up already..are the installation procedure the same? I'm thinking Tein S+ illumina or just get JIC..any suggestion?
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Ben2003GLE
Sep 24, 2015 04:25 PM
