BlehmCo BBK...review and some pics...
Old May 9, 2004 | 06:37 PM
Colonel's Avatar
Old Fuddy Duddy
OK...I have had my BBK for about 1 full month now and figured it would be time for a review.
Wear:
Today I pulled it apart, to see how things were wearing and if anything funky was going on. Right now I have a "ridge" on my pads at the very top, as if the full pad is not on the rotor. Not sure what long term effect of this is. Maybe quicker pad consumption? That seems to be the only usage negative that I can come up with so far. No squeaking (I used the Nissan 300Z shim kit and any squeaks are now history). I also used anti-seaze grease as my anti-squeak grease
Performance:
Well, lets say that I spanked out a personal best of 108ft. 60-0.
I was using the same road, same conditions (as much as possible...atmospherice temp was 10 degrees more) and tires had accumlated 380 miles since last test. I was averaging stops of 112.789 with the new equipment.
BUT, tires are the limit of the connection to the road...I had to really learn how to modulate the pedal to get the stops down that far. Just cant romp them like I used to w/o the anti-locks getting all happy. I was drifting into higher stopping number becuase the ABS was kickin.
Pedal feel is GREAT. I put on the SS lines and its is FIRMER than stock with rubber lines. I think this is the BEST part of the whole kit. No more mushy crappy yucky Nissan pedal. I really think most would get a better feel just doing the SS lines.
Also no fade. I was pounding these brakes and for sure, they "could" be tracked happily. I dont track so thats pure suggestion/assumption.
Pics:
Old May 9, 2004 | 07:33 PM
kwd2kSE's Avatar
Colonel, so everyone would have comparable numbers, I copied the 60-0 data from your previous thread on the stock brakes. Here it is....
"Went to my favorite spot to do some brake testing. I did 10 runs in about 25-30 minutes. Each run was accompanied by about a 2 minute cycle to get turned around, cool brakes and set up for next run.
1) 148 Ft (ouch)
2) 141
3) 132
4) 135
5) 127 (wow)
6) 129 (smoked something as a puff of smoke came from right front after stopping)
7) 133
8) 138
9) 137
10) 142
I used a borrowed G-tech unit. I "assumed" it was level at start with a .00 tilt and at the end of the run it was a -.01 tilt. Close enough I guess.
So I guess I am going to use these as my baseline numbers. Obviously as the brakes heated up I got some better stops, but by run 7 I believe that they were starting to overheat a bit.
Other notes:
1) Temp was between 69 - 71.
2) No direct sunlight
3) only 20 miles on a full tank of gas
4) Michelin Pilot A/S with about 11K on them. Rotated at 5K intervals.
What do y'all think...good enough for comparison?"
Copied from this link.http://forums.maxima.org/showthread.php?t=297437
To go from 127ft. on the stock brakes, to 108ft. on the new brakes, thats a HUGE improvement. Nice with someone that has G-Tech data to show the improvement over stock. And yes, I have the same setup, mine was the test mule for the system.
Mike
Old May 10, 2004 | 03:37 AM
UMD_MaxSE's Avatar
Got Bent?
I get my Z calipers and hardware today hopefully... Rotors will take longer since I ordered slotted only... looking forward to it
Old May 10, 2004 | 04:47 AM
schernov's Avatar
[QUOTE=Colonel]OK...I have had my BBK for about 1 full month now and figured it would be time for a review.
Wear:
----> As you mentioned 300z shims, I assume you have 300z calipers right?
As far as the ridge on the pad. I just helped a guy do his front brakes on a full size Chevy Z71 pickup and he had the same deal - Once the ridge gets bigger, they will start squicking. Once of his pads cracked because of the ridge hitting imperfections on the top side of the rotor ...
Old May 10, 2004 | 05:01 AM
spirilis's Avatar
I'm curious about this "ridge" in the pad, although I'll be using stock calipers...
Old May 10, 2004 | 05:21 AM
spirilis's Avatar
I should be getting my order from DAVEB soon (OEM 2k4 rotors, a few miscellaneous items)... should be this week, come on damnit I want my brakes!
and now, for a haiku...
I hate my car's brakes
They make me fear every damn stop
BlehmCo solves it all
(or so we hope )
Old May 10, 2004 | 06:28 AM
Colonel's Avatar
Old Fuddy Duddy
Mike
Hey Mike!
Would you mind (I know..BIG request) popping off a caliper and checking to see if you get a ridge in the pad. Its going to be the side closest to the outer diameter of the rotor. I need to make sure I did not assemble wrong (not TOO likely...but possible) or there is a measurement thingy happening.
Thank!
Old May 10, 2004 | 06:30 AM
Colonel's Avatar
Old Fuddy Duddy
Yes, I have 300Z calipers...and yes...what you mentioned above I am worried about. But I know Matt will come to the rescue and let me know whats up...so no real concerns.
Old May 10, 2004 | 08:12 AM
JdoubleOe703's Avatar
teddibear703
i think the ridge is caused by the relocation bracket being slightly to high, thus there's no contact on the area causing the ridge? maybe the relocation bracket should be moved down a littl?
Old May 10, 2004 | 08:18 AM
Colonel's Avatar
Old Fuddy Duddy
Yes, I agree. It would SEEM that the bracket mount the caliper about 2-3 MM to far away from the spindle. BUT...I have to verify with Matt its not an assembly error on my part.
Old May 10, 2004 | 08:42 AM
Matt93SE's Avatar
STFU n00b!
The problem with it is that the 300ZX calipers and pads are designed for an 11" rotor, and we're putting them on a 12.6" rotor. the shape is different and you can't stick the caliper all the way down like you could with the 11" rotor.
It's a tradeoff, but it's not going to hurt anything. I've seen many other systems like this (as well as my Wilwoods I've been using for over 2 years), and the only drawback to it is that you're missing that 1/2% of the pad's surface area on the rotor.
If you can move the calipers down a bit, it might help- but make sure it doesn't rubthe rotor. There's a little movement in the bolt holes so you should be able to loosen the bolts and move it a mm or so, but I'm not sure if that will fix the issue or not on yours. I left a little extra in them just to make sure they'd fit everyone's car. you never know if they've had a wheel bearing changed and things are a little out of whack.
Old May 10, 2004 | 08:53 AM
spirilis's Avatar
Cool, so this shouldn't be a problem for OEM calipers?
Old May 10, 2004 | 11:29 AM
kwd2kSE's Avatar
Originally Posted by Colonel
Hey Mike!
Thank!
Not a problem Colonel. Actually, you don't have to remove the calipers to take out the pads, so its no big deal. As Matt said above, the little bit of the pad-about 1mm on mine-that does not contact the rotor is just part of the trade off of this setup, and I consider it a non-issue. You can't lower the caliper enough for full pad contact without the caliper rubbing the rotor, or grinding the caliper to get it lower on the rotor(which I would NEVER do). Don't worry, you are in good shape and everything sounds right.
Old May 10, 2004 | 11:32 AM
kwd2kSE's Avatar
This is not a problem with the stock calipers either. I can speak on this, since my car was also the test mule for the stock caliper setup also.(Its my white 5th Gen in all of Matt's BBK pictures!! Shameless plug for myself>)
Mike
Old May 10, 2004 | 11:36 AM
irish44j's Avatar
retired moderator
colonel.....I'm assuming you're using the 300ZX calipers. I am using my OEM calipers and I also get the small ridge on the top of the pad where it does not contact the rotor.....doesn't seem to be a problem.
Old May 10, 2004 | 11:41 AM
spirilis's Avatar
hmm, I'll have to see about making sure all free-play in the bolt adjustments pushes it downward... I doubt this'll be a huge problem, although I wonder if the pads will squeal later on as they wear down (from that little bit of material hanging over the edge--or does it actually hang all the way over the edge?)
Old May 10, 2004 | 11:45 AM
UMD_MaxSE's Avatar
Got Bent?
Just got my calipers, pads, SS lines, hardware, and shim kit... just waiting on rotors now...
Thanks Larrio!
Old May 10, 2004 | 12:18 PM
Colonel's Avatar
Old Fuddy Duddy
Thanks Larrio!
I will say this...you are going to like them. I surely did myself!
BTW, the little clips in you shim kit goes on the bottom of each pad. It holds the slotted and solid shim close to the backing plate of the pad. You have 2 of each shaped the same way. The gold packet is Nissans anti-squeal, but its really anti-seaze. So go buy a tube of the silver kind and use liberally. If you already knew this stuff...consider it a broadcast to the public then...hehe.
Over all, I am going to play the wait and see game with the pads...I inspect my car often (as I am a geek and tinker with my car almost all the time) so I am not to worried about failure of the pad.
As for the ridge itself squeeking....Ill wait and see on that one too.
Old May 10, 2004 | 12:24 PM
Colonel's Avatar
Old Fuddy Duddy
Thanks for the input....Seems like a lot of people say this isnt a problem.
But (devils advocate here, take a such) as you wear into your pad more and more, you are going to get a "hangy" of pad. I am "guessing" that its possible for this to break off? If so, is the pad integrity compromised?
I am not pulling the system out, as these brakes are awesome for me. Just need to make sure I understand everything and maintain it properly.
Old May 10, 2004 | 01:52 PM
UMD_MaxSE's Avatar
Got Bent?
thanks for the info! I knew how to put all the shims together. Didn't know about the gold colored grease though... I thought it was just plain old anti-squeal grease.
Old May 10, 2004 | 03:13 PM
irish44j's Avatar
retired moderator
Originally Posted by slammed95
This kit is excellent as an inexpensive upgrade for regular street driving, but will not produce the numbers shown on the G-Tech.
this coming from the guy with a hyperlink to AP Racing Brakes in his signature.....sure you're not jealous that his "inexpensive" upgrade works as well as the AP Racing kit?
...and an "upgrade for regular street driving"...no ****....last I checked no one here is driving the maxima in the Grand Prix of Monte Carlo...so why would we need silly 6-piston brakes with 14" rotors or whatever?....
As for me, I am getting a roof-mounted air brake, similar to the ones used on an F-14 Tomcat when landing on a carrier....just pops up hydraulically!
Old May 10, 2004 | 03:42 PM
Larrio's Avatar
The Definitive AE Master
heh... i don't think he's jealous of the Blehmco kit. I'm sure everyone has their own priorities as to performance modifications. I don't think he meant it as a remark on the quality/performance of the kit, rather just pointing out that the g-tech is rather inaccurate at times.
oh btw, UMD: no problem... hope u like the brakes
Old May 10, 2004 | 04:35 PM
irish44j's Avatar
retired moderator
Jealous? Naw, I'm happy with these:
I don't know what you're so upset about, I was simply giving some factual info. I really like this brake kit, and would consider it for my '02 max. What I meant was that "regular street driving" doesn't include doing 100+ frequently, having turbo assisted acceleration, or going to the track.
Many props to Matt for putting these together, he's a pioneer in the maxima community for innovative parts
yeah hotshot, I saw them in your signature. show off!
I'm not upset, man.....just givin you a hard time
ok ok one thing though....not really sure what a having a turbo has to do with your brakes. Does a turbo with OEM brakes take longer to stop than a non-turbo with OEM brakes? Just wondering what you meant by that. man, you showin off again by droppin the "t" word?
I would love to get a true BBK or even the BlehmCo with the Z calipers, but unfortunately none of these will fit under the 2k OEM 17's, so I had to get the BelhmCo kit that uses the OEM calipers..Would get bigger rims but already bent one of my OEM 17's with all the potholes round here...so Matt's kit is as big as my brakes will ever get.
Old May 11, 2004 | 02:20 AM
spirilis's Avatar
That's probably a lot of us. BTW, my shipment from DAVEB just arrived, 2 2k4 rotors, 2 of those spring-clips that hold the brake hose to the strut (I'm missing my front left one ) and a replacement dust cap for the right rear hub dustcap I think (had to punch a hole in it to remove it last summer when I was doing the rear brakes... rear rotor was stuck so I needed to use a puller on it)
BlehmCo BBK here I come... after I buy a 22mm box-end wrench and another 22mm socket
Old May 11, 2004 | 05:20 AM
Matt93SE's Avatar
STFU n00b!
Oops... Forgot to reply to this yesterday.. had a little drawing done up for you guys and my computer crashed.. didn't have time to redraw it before I had to head to UPS to ship some parts. blah blah blah..
Anyway, here's WHY the pad hangs over the edge of the rotor.
(this goes for ALL calipers used on rotors bigger than they were originally designed for, not just the nissan ones specifically)
The pad and caliper are both designed for an 11" rotor (in this case). When you stick a 12.6" rotor under there, the curvature at the end is slightly different.
What I've done in this drawing is draw the factory-sized 11" rotor, the 12.6" rotor, and the pad positions relative to where they sit inside the caliper- and on the rotor
you can now easily see why there's a bit of overhang on the pad.
No, it's not hurting anything- note the overhang is a very small percentage of the total pad surface. (roughly 1%)
As has been mentioned, this kit is designed for those of you, like Colonel for example, that just want better braking on the street. Those of you that are hardcore track guys, you'd be better off with some 2-pc rotors that will stand up to the heat. the Z calipers are up to the job- especially since you can get just about every pad compound known to man for them.. There's really no difference between them and my wilwoods, other than the name stamped on them. (I'd venture to say that the Z calipers are probably stronger than my wilwoods even) Old design? Maybe- but they overcame the lack of technology with more metal. they're a bit heavier than the Wilwoods, but they do the same job. But back to the point..
These brakes will do everything 99.95% of the people out there need. that last 0.05% needs to go spend $2500 on an AP or Brembo kit and pay $350 a rotor and $250 for replacement pads. the rest of us will smile when we look in our wallets and have money left over for another set of auto X tires.
Old May 11, 2004 | 05:27 AM
UMD_MaxSE's Avatar
Got Bent?
Does anyone have a pic of how the 300Z relocation bracket bolts on to the steering knuckle? Just wanted to verify it's location... thanks!
Old May 11, 2004 | 05:30 AM
spirilis's Avatar
I pretty much realized why the pads overhang like that once I thought about it... larger rotor diameter = less dropoff/distance as you draw the circle away from a tangent point. Makes perfect sense. Although I would imagine you could still dial out that ridge by moving the caliper further in, except I realize the problem applies to the shape of the caliper too, not just the pad, thus you would start scraping between the rotor and the outer edges of the caliper if you moved it further in. Oh well, no big deal.
Old May 11, 2004 | 05:37 AM
Colonel's Avatar
Old Fuddy Duddy
The kit looks pretty good, like it should have come that way from the factory.
However, I highly doubt that the G-Tech is close to accurate. They're known to produce very incorrect readings. If the stopping distances are correct, that would mean your stopping shorter than a Roush StageIII Mustang with 14" 4pistons, a Corvette with 14" 6 piston front and 13" 4 pistons, a Porsche GT3, and a Ferrari Enzo. There's no way a maxima can do that with a few replacement brake parts.
Oh, I know the G-Tech isnt overly accurate...BUT, I tried as best as humanly possible to keep all the "other" variables consistant (temp, time, same stretch of road). But doing this, the "inaccuracies" of the G-tech where perpetuated in both tests. In theory, regardless of the actual number, we might be able to assume that the kit dropped a rough 15-20 off the stopping distances.
I am not challenging the inaccuracies of a G-Tech...but the inferences you are putting up are not very nice. Why in the world would I lie about numbers...I could give a rats rear what the "public" thinks. Nobody EVER did a before and after...and I did. Thats what the device posted...and so did I. If you have pre and post brake numbers, I would be glad to look at them and maybe detect what went wrong in my testing scenario.
Remember, I have not declared these numbers as god gift to braking numbers. Only numbers that I have recieved via an unit attached to the window. Nothing more. More of a baseline reference number.
Thanks, and have a good day.
Old May 11, 2004 | 05:41 AM
Colonel's Avatar
Old Fuddy Duddy
LOL, Yeah I do...one thing I think Matt needs to do I spent about 15 minutes verifying the location. I can email it to you, as the cardomain ones are to small to see it correctly.
Basically, there is a curve in the bracket. That curve goes up against the spindle.
Old May 11, 2004 | 05:51 AM
kwd2kSE's Avatar
Check out the pics on Matt's web site from the link below. Specifically, pics 722 thru 725 should show what you need. Also pic 735 shows the back side with the caliper and brake line on too. That's my caliper in the pic, how do you like the color?
http://www.mattblehm.com/HSS_images/...0zx_brake_kit/
Old May 11, 2004 | 05:57 AM
UMD_MaxSE's Avatar
Got Bent?
thanks guys... those pics show it clearly...
Old May 11, 2004 | 05:58 AM
UMD_MaxSE's Avatar
Got Bent?
o and the red calipers look really good...
Old May 11, 2004 | 07:20 AM
00MAXIST's Avatar
Need help in determining whether or not I have the shims installed. Anyone?
Old May 11, 2004 | 08:33 AM
kwd2kSE's Avatar
The shims that are talked about here are VERY thin metal pieces that go between the back of the pads and the caliper pistons. They clip on to the back of the pads, and are roughly the shape of the pads. One of the shims looks like it has vertical slots cut in it, like a cheese grater. I believe all the Z32's have two shims behind each pad-one vented as I said, one solid. The solid one goes next to the pistons.
Here's a really good web site that illustrates the above.
http://www.ttzd.com/tech/brakestech.html
Old May 11, 2004 | 08:53 AM
spirilis's Avatar
I just did a google search regarding shims, since I never use them either. One person suggested the shims may be used as the disc brake "wear indicator", i.e. if the shims have a piece that folds around the pad, it can be used as a wear indicator which scrapes the rotor when the pads wear down far enough. Probably useless to most of us, but I wonder if a car could fail some states' inspections due to this...
UMD_MaxSE's Avatar
Got Bent?
dont forget about the small clips that hold the shims in place either...
Old May 11, 2004 | 09:07 AM
Matt93SE's Avatar
STFU n00b!
Whoever said that needs to be smacked in the head. the shims are so thin that by the time you're rubbing on ths shims, you're going to be down to bare metal by the time you can get home. they're about 0.5mm thick or so, and the pad wear limit is 2-3 mm. well past the wear limit for the pads.
Old May 11, 2004 | 09:14 AM
spirilis's Avatar
Even the clips that go around the pads? (if they do, that is... I haven't looked at one in almost 9 months )
Old May 11, 2004 | 09:26 AM
Colonel's Avatar
Old Fuddy Duddy
The wear indicator on the 300Z pads are attached to the pad itself and has nothing to do with the shims in any way what so ever. The shims are to keep the backing plate on the pad from rubbing or vibrating in the caliper, which is one source of squeaking.
The clips, IMHO, are only there to keep it together long enough when you reassemble the pads. I put them on, and I get no squeaking...so no changes here.
Old May 11, 2004 | 06:24 PM
spirilis's Avatar
Installed the kit this evening. I love it
I did run into a minor snag, or something. The left wheel seems to have a periodic (i.e. repetitive, you hear it once with every revolution of the wheel) scraping sound, which you can hear initially while rolling out of the driveway, and I could hear when I was rolling the wheels with the car jacked up. Not sure what it is, almost sounds like the rotor periodically touching the pad and moving away, as if the rotor (or something else) was slightly out of round. Not sure.
Either way, it didn't influence brake performance, as the pedal is perfectly smooth and there is no vibration, and the braking torque is amazing--I found myself routinely hitting the pedal as hard as before, only finding myself backing off the pedal very quickly since the braking power is markedly greater than the old setup I had (Raybestos rotors with Raybestos QuietStop pads). I think I did notice the PBR Metal Masters' high temperature effect, where the pads start to grab harder when they heat up. I tried not to heat them up too much, instead going by a lot of gentle slow downs/stops, similar to the 30-5 stops followed by a cooldown period recommended on the sheet that came with the pads.
I'm gonna have to monitor how the car sounds from here on to see if that periodic "scraping" noise subsides... it does worry me, but at least I can drive it to work for the rest of the week, god forbid it somehow escalates into an issue.
I do recall that the top bracket-to-caliper bolt was difficult to install, in that I had the bottom one already installed and the top one seemed to go in with an occasional "scraping" noise. After backing out the bolts, I noticed the threads look somewhat flattened, but the bottom bolt looks like that too and I didn't have any trouble with it. I haven't removed the right side's bolts for comparison. Worst comes to worst, if this is the result of a slight crossthreading, I'll have to buy new mounting bolts from Matt, and a new caliper mount from DAVEB, hopefully that wouldn't be too much... but I pulled it out and re-tightened it as squarely as possible (could still hear the periodic noise), we'll see how it goes.
I can say that with PBR (Axxis) Metal Masters, the BlehmCo BBK kit with Genuine Nissan OEM 6th gen rotors BARELY fits. I mean, BARELY. You really have to push that caliper piston in there, and if you take the caliper off shortly after test-driving the BlehmCo kit and attempt to push the piston back into its bore, there's only ~1-2mm of movement before it hits rock bottom. Wow
