Bad Power Steering Pump?
Old May 10, 2004 | 10:19 AM
rachwalj's Avatar
I have an 03' SE 6-speed and it sounds like the powersteering is out of fluid, but there is no fluid loss. Only when the tranny is engaged and going slowly while turning, I hear the whirring type noise.
Has anyone else had a similar experience?
Also, any recommendations for spark plug replacement?
Old May 10, 2004 | 10:29 AM
SoonerFan's Avatar
Cletus
does it only do it when you turn sharp (steering wheel turned all the way)?
if so, thats normal.
most common way a pump goes bad is a bad seal. you would see fluid dripping and the resevoir would be empty. and you would be able to tell when steering. it would be very hard because your power steering is not working.
mine went bad and it was a pain!!
Old May 10, 2004 | 11:02 AM
2002 Maxima SE's Avatar
Spark Plug Change
Old May 13, 2004 | 11:40 AM
rachwalj's Avatar
Originally Posted by 2002 Maxima SE
What type of spark plugs do you recommend? I can't seem to find any on the net for an '03 Max. All the stores claim that such a part doesn't exist. There are some for the '01, but the engine is a bit different.
-Jason
Old May 13, 2004 | 01:49 PM
VMaximus02's Avatar
Trying flushing out the old fluids and replace it w/synthetic Auto-trans. oil.
I empty mine and refilled the reservoir twice within a month interval with Amsoil ATF. The steering now seems to work better at all temperature and probably the steering units will last longer too.
I've recent changed my sparkplug w/Denso Irridium brand. It performs just fine thus far...
Old May 13, 2004 | 06:21 PM
-Jason
NGK platinum.
Old May 14, 2004 | 06:44 AM
rachwalj's Avatar
As I am under warranty and there is definitely something wrong, I have scheduled an appointment. I will let everyone know if there is some sort of defect or problem. Thanks for the replies.
I did all the Amsoil stuff. Manual transmission fluid and the 0w-30. So much better...
Did you notice any perfomance increase with the Denso plugs?
Where did you buy them?
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
trungg86
Sep 4, 2015 04:58 AM
coasterswim
Sep 2, 2015 07:43 AM
