Problem: Powerloss and whine when the A/C is on...
Old May 19, 2004 | 10:52 AM
NYCe MaXiMa's Avatar
.. Recently, i've started the use the A/C more since it gets real hot out now.. so I was driving around and noticed the air conditioner is really weak. I was on full blast and it was not very effective, it cools but not so well. So I thought i just need to recharge it.
Later, I noticed that the car feels really sluggish, I know that cars don't perform as good with the A/C on but it was REALLY bad..
then, I noticed that when i get to 3k RPMs and above, there is a noticeable whine coming from somewhere... sounds like a ghetto blow off valve..
so what can this be?
My guess is the A/C compressor belt? but what's happening, is it slipping or can it be too tight? i checked it and it seemed alright. A bit hard though...
how do i go about in fixing this problem?
thanks
Old May 19, 2004 | 02:00 PM
paralyse's Avatar
I Miss My Maxima
Your compressor might be binding or locked up, creating drag, and causing your belt to slip (hence the noise, and power loss)
Old May 19, 2004 | 02:09 PM
thanks
any way i can single out the problem? check resistance or something?
Old May 20, 2004 | 01:44 PM
Old May 21, 2004 | 05:07 AM
fishhouse's Avatar
my 2k does have somewhat less power when the ac is on (as i think everyones will)...but sounds like yours is much more significant.
Old May 21, 2004 | 08:00 AM
CVicVogel's Avatar
NYC
Before you spend a dime on A/C charging or diagnosis, be sure you replace your cabin air filter (if you have one).
A clogged cabin filter will reduce airflow and cause whinning noises from the interior fan. Had a similar problem with my previous car...replaced the filter that helped.
There are on-line tips in the forum on how to replace it.
Vic
Old May 21, 2004 | 09:02 AM
Max2000SE's Avatar
I think the whine is normal. I have the same thing and it does it when the defroster is on as well...Its funny b/c it does sound like a cheap blow off valve. DOesnt bother me too much though
Old May 21, 2004 | 09:11 AM
maximo-SE's Avatar
i had two cars now, and the ive noticed when the AC is on, the car is slower at acceleration...... i think its normal since AC drains a lot of gas. I might be wrong. someone can ad to this.
On the whining part.... my AC whines.... really low whine, i guess thats the noise of the Ac compressor.... guess its normal....
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
dcam0326
Sep 18, 2015 04:52 PM
EdRomo86
Sep 12, 2015 07:49 PM
