Bad starter motor?
Old Mar 26, 2001 | 10:38 AM
Adam01GXE
Have any of you guys experienced problems starting your cars? At kind of random times my car acts like it doens't want to start at all. I'm pretty sure its not the battery b/c the car doesn't seem to be winding up, but rather sounds like its just not catching. I at first contributed it to cold weather, but the other day it was 60 and the car had trouble starting. Any thoughts?
Old Mar 26, 2001 | 11:03 AM
Lumbee799's Avatar
I have had it happen twice so far. Starter is spinning but engine is not catching. I believe there was a similar post around here and said to just give it a few seconds and try again.
Old Mar 26, 2001 | 11:31 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I've had this happen several times.
I believe it's a "starter disable" problem with the microchip in the key. After a few seconds of cranking the "access code" is finally given and the engine starts. Maybe, when you put the key in the ignition you need to give it a couple seconds. I also think certain interferance problems could screw with the process every now and then.
I've seen a TSB or something related to this problem. I remember someone having to have their keys recoded to fix the problem. I haven't had the time to investigate getting this fixed yet.
Old Mar 26, 2001 | 04:30 PM
Adam01GXE
Thanks, hopefully that's all it is.
Old Mar 26, 2001 | 06:30 PM
Wustylez
Read your manual, it addresses such problem---pressing your gas when the engine is cold or hot(hard to start)etc....
Tim
Old Mar 26, 2001 | 07:15 PM
Adam01GXE
Tim
Shouldn't pressing the gas actually flood an EFI engine?
Old Mar 26, 2001 | 07:32 PM
IceY2K1's Avatar
If the problem starting is due to lack of fuel, when you turn the key to the on position, you are turning on the fuel pump which will pressurize the fuel lines. So you shouldn't need to pump the pedal, because the injectors will already be suppling enough cold start fuel enrichment.
Old Mar 26, 2001 | 07:37 PM
MrBurner's Avatar
this happens to me once in awhile and i have 15k miles...hasn't happened for a few thousand miles, but it's really embarassing when you are with a new girl or when you are outside of a performance shop and you car almost sounds like it won't turn over for a couple seconds
Old Mar 26, 2001 | 08:10 PM
Wustylez
It's in your car manual..read it..it's there i don't know if it will flood the EFI or what not.but that is what manual suggests!!!!
Tim
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
vball_max
Sep 17, 2015 10:01 AM
jwright36
Sep 8, 2015 11:45 AM
