VQ35DE problems!
Old May 20, 2004 | 03:16 PM
MiniRX7's Avatar
VQ35DE problems!
Hey guys... weird...
I noticed my engine is rattling a bit..
SO i noticed on a little tap on the throttle in neutral, and i hear this rattling noise coming from the engine.
I don't know what it is. The car drives perfect. But the noise is concerning me.
ED
Old May 20, 2004 | 04:09 PM
celica's Avatar
cam sprocket tsb, my cars is in the dealer for the same noise and they acted like they ain't here it but the i made my boy who is the service writer hear it when we was in an inclosed garage and now they have to fix it. but if they act stupid with it i'll just deal with the rattle before they mess somethin else up tryin to fix it.
Old May 20, 2004 | 04:52 PM
Y2K2Driver's Avatar
Is this another incident of the infamous throttle plate screw coming loose and getting sucked in? If so, you'll need a new engine.
Old May 20, 2004 | 09:00 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You just waiting for these like I am?
MiniRX7,
Unhook that bellow piece that connects to the throttle-body and peak inside at the throttle-plate. If there isn't TWO screws there, you need to put your car back to stock and prepare for the dealer to get you a new engine.
Keep us posted on what you find out.
Old May 20, 2004 | 10:35 PM
Fezzik's Avatar
Do you have this cam sprocket TSB? I would like to take a look at this and take this to the dealer. I was told this may be a possible problem of why i get this rattle. Thanks!
Old May 21, 2004 | 01:45 AM
Y2K2Driver's Avatar
It certainly appears that way. It's my sixth sense.
Old May 21, 2004 | 02:57 AM
VQ35DE's Avatar
It is NTB03-060. Look in tsb forum.
Old May 21, 2004 | 03:13 AM
SoonerFan's Avatar
Cletus
or here
http://maxima.theowensfamily.com/tsb/
Old May 21, 2004 | 05:52 AM
nissan5788's Avatar
The TSB is only for that rattle that comes immediately after starting the engine. I think the rattle he's talking about is different. I get that rattle too, in neutral and around the 1800-2200 RPM mark. Went to the dealer several times for it, they don't know what it is (1st blamed it on gas, 2nd time on sensor recall, 3rd bent heat shields, etc etc).
Does anyone have a pic of the TB and what to "unhook" to check if the 2 screws are there?
Old May 21, 2004 | 05:57 AM
celica's Avatar
MiniRX7,
well that actually might be the problem for that since i jus got my tb replaced and i do think it start get the noises way louder then before when the check engine light came on for the tb. so check for the missin screw first. and if its trully that i need a new engine i doubt they given me that. o well most liekly will have to live with the noise.
Old May 21, 2004 | 07:06 AM
Rafe's Avatar
You know fellas, that rattle that you hear when you start your engine i had that too, but min went away when i had the Crank angle sensor TSB done on my car, now i have no more rattles. i could contact my dealeship and ask what the tech did to remove that rattle .
Old May 21, 2004 | 07:07 AM
MiniRX7's Avatar
OMFG..
I am goign to check..
Heres the thing, it sounds like VALVE chatter, but even louder than before.
The oil i am using is the AMSOIL 0W30 Series 2000... I change the oil every 9000KMs (not miles)..
I wonder if the weight of the oil is too thin causing excessive valve noise.
Old May 21, 2004 | 07:08 AM
s_hinerman's Avatar
That would be cool becuase there are a lot of us on here with problem.
Old May 21, 2004 | 08:00 AM
IceY2K1's Avatar
Yeah, when you FIRST start up the car, you can get timing chain slap or valves clatter before the oil gets up there.
However, he's talking about tapping the throttle. If it gets louder with RPM, it could be the METAL PIECES bouncing around in the cylinder from the broken up screw.
Pull the plastic "accordian" looking piece that attaches to the TB and peek inside with a flashlight. All you need is a screw driver to loosen the hose clamp and 30-seconds.
Old May 21, 2004 | 08:07 AM
hansolo1's Avatar
I also hear a rattling or clattering noise between 1800 and 2200 RPM's. Accompanying this clatter is also a vibration that I can feel in the gad pedal. I've had this problem for as long as I can remember. I've brought it to the dealer twice and I get the usual," can't duplicate problem". Has anyone been able to figure out what is causing this?
Old May 21, 2004 | 08:44 AM
celica's Avatar
well i get the rattle when revvin the engine and as soon as i let off u hear the exact same noise i get when cuttin the car off and startin. goin to the dealer in a few to see if they actually goin to fix it or claim some crap again. i only complained about the noise on start up so if they do fix that and i still hear the noise when revvin i'll let yall know
Old May 21, 2004 | 08:57 AM
Rafe's Avatar
Sorry man ...i called and all they did witch was mentioned in the earlier post was basiaclly tighten my timing chain while they were in there. I had the "timing chain slap" syndrome, that other noise,you got me too..... man it doesn't too good in your case.....
Old May 22, 2004 | 07:43 AM
celica's Avatar
well got the car bac yesterday. well the noise some how disappeared for a while so the tech ain't hear it, and the service writer tried to see if i can make it happen again and for some reason all the rattles disappeared. surely soon as i left the dealer they came bac so i don't care for them right now. the start up rattle is practically silent ( still hear it a little) right now when it was loud all the time before and the rattle when u rev is loud as before but car runnin strong as hell so i live it for now. put berk intake back on and boy does that top end feel nice
Old May 22, 2004 | 08:01 AM
SR20DEN's Avatar
VQ Wizard
I have a rattle in mine but it's the clutch disc going bad again. If any of you guys have 6 speeds just push in your clutch to see if the noise goes away.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
