Progress Rrear Sway bar
Old May 20, 2004 | 04:02 PM
hct67's Avatar
Progress Rear Sway Bar
What kind of effects will I feel with the Progress Rear Sway Bar on my 03 Maxima? I just got it installed today and really haven't taken the Max for a strong drive yet!!
Also I have the Tokico Blues and Tein H Techs installed With a Front Strut Bar.
Old May 20, 2004 | 05:41 PM
SEmy2K2go's Avatar
Go BUCKS!!!
You should see the biggest differences when you are on exit and entry ramps, but overall the rear end will just feel more planted.
Old May 20, 2004 | 07:10 PM
01SE02SER's Avatar
Faster than a speeding bullet...
Agreed. If I could grow an extra thumb to recommend an RSB, I'd give it three thumbs up!
Old May 20, 2004 | 07:36 PM
Mick Max's Avatar
Wild at Hurt
The Max REALLY needs this because without it it is an understeering pig.
Old May 20, 2004 | 07:53 PM
2001SE's Avatar
yep...def needs one. My first suspension modifaction and very worth it, holds the back very nice compared to stock.
Old May 20, 2004 | 10:56 PM
808MAX-SPEC's Avatar
Don't get carried away when you're making turns. You'll feel like you want to go faster while turning.
BTW - if you hear a klunk, that's the control arm snapping back the rear axle (now that the RSB is mounted to the axle). So go over speed bumps and drive ways slowly. Dips in the freeway can't be helped.
Old May 21, 2004 | 09:21 AM
maximo-SE's Avatar
RSB gets rid of whale like movements of the beautiful max.
its basically essential...
Old May 21, 2004 | 02:36 PM
MaxArt's Avatar
I agree with all of the positive comments on the Progress RSB - wish I had known to put a RSB on my '98 (I think my '93 SE had the best Maxima suspension ever right from the factory). I enjoy the improvement most on sweeping turns and ramps. While I enjoy the softer ride of the GLE than my two SE's had, I found the bounding on bumpy turns disconcerting - having to constantly correct for the changes in understeer during undulating corners. Now it stays planted on a constant radius even when there are bumps with no more bounding rear end. Now I feel like I have the best of both worlds; nice ride and excellent handling.
Old May 21, 2004 | 03:45 PM
8702's Avatar
is stillen the only adjustable rsb? what's the advantage of having it adjustable as opposed to a fixed design?
Old May 22, 2004 | 07:37 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
I agree with you about the 3rd gen suspension MaxArt. Had I known how great my '94 SE handled out of the box compared to the newer ones, I would've stalled buying my '02 a couple yrs ago. But damn that 3.5, 6-speed, HID's and all those other goodies just SUCK you right in. hehe
Is progress the best RSB for our cars night now?
Old May 22, 2004 | 02:54 PM
hct67's Avatar
Noise/Klunk
I was wondering what that sound was, At first I thought it was the muffler hitting the body. Anyways, I took it to the garage where I got it put on, we took a drive and hit some bumps and that loud clank was there. Is there anyways of fixing that. I hate that sound and it sounds like its going to break. So its the control arm snapping back the rear axle? Please tell me theres a way to fix that problem!!!!
Old May 22, 2004 | 05:45 PM
cobymoby's Avatar
On my sway bar I had to shave off a corner on the passenger side sway bar bracket that goes over the axle with the big "U" bolt. Jack the car up and you'll see where you need to shave it off.
Old May 22, 2004 | 06:22 PM
hct67's Avatar
Help
So your saying shave off the U Bolt and make it flat with the bracket? Do you have any photos or could you take some so I can see.
Old May 22, 2004 | 08:42 PM
TonyMaxNismo's Avatar
is there a major difference between the progress and stillen sway bar as far as performance wise?
Old May 23, 2004 | 01:18 PM
hct67's Avatar
Help
So does anyone have this Klunking noise with the Progress Rear Sway Bar and if so what have you done to fix this problem?
Old May 23, 2004 | 01:21 PM
jeepik's Avatar
i have no noise on my Progress bar. it shouldnt be making noises
Old May 23, 2004 | 01:55 PM
Regime's Avatar
The non-postwhoring Org member
First you need to push the u-bolts and brackets as far outward they can go on both sides of the axle. if it continues, then shave off the rear part of the passenger side bracket, Not the U-Bolt, the Bracket.
Old May 23, 2004 | 03:17 PM
hct67's Avatar
Pictures
Do you have any photos of what yours looks like?
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
