P0420: Catalytic Converter Efficiency Below Threshold Bank 1
Old May 21, 2004 | 01:01 PM
TZapper's Avatar
Hi All,
I went ahead and retrieved the P0420 code from my 2000 Maxima SE (50k miles). Now I know it can either be the bad O2 sensors or the cat in fact went bad. But how do you narrow down the problem? I also think that exhaust smells somewhat like rotten eggs, but I am not sure.
Any advice on what I should do? Will Nissan cover it?
Also, I remember someone posting a link to a large text file with full and detailed OBD2 code descriptions, anyone know it?
Thanks in advance.
Old May 21, 2004 | 01:22 PM
DanL's Avatar
Originally Posted by TZapper
Hi All,
Thanks in advance.
Read the FOLLOWING TSB . Take it in to the dealer. If you have a California spec car they'll
probably just reprogram the ECU. If not, the catalytic converter may actually be bad, but in any case, both are covered under the 8/80 Federal emissions warranty.
Old May 21, 2004 | 02:32 PM
maxcozmo's Avatar
The code P0430 popped up in my 2k. Both the dealer and nissan usa said they could do nothing unless I replaced my muffler with an original.
Old May 21, 2004 | 02:41 PM
maxcozmo's Avatar
Hey DANL. Does that tsb also cover the code P0430?
Old May 21, 2004 | 02:46 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Well I wouldn't change the 02s, I'd go in for the TSB reflash.
However, the rotten-egg smell usually means a bad cat, however that should be covered under the emissions warranty BUT check your Owners' Manual to know for sure.
Old May 21, 2004 | 03:17 PM
IceY2K1's Avatar
No, but it's the SAME problem just other bank setting it off.
There might be another TSB for that code, but *HOPEFULLY* your dealer is smart enough to read. Probably not though.
Old May 21, 2004 | 03:46 PM
TZapper's Avatar
Found out my car is Cali spec, so it seems that the ECM needs to be reprogrammed. Will visit the dealer soon.
Thanks all.
Old May 21, 2004 | 03:51 PM
IceY2K1's Avatar
Good, should be covered until 80K as DanL previously mentioned.
Old Jun 17, 2004 | 01:35 PM
foodmanry's Avatar
Da Roller Coaster!
Ok I just threw the same code. I cleared it while at Autozone. I'd like to take it in to the dealer to have the ECU flashed, but I have an aftermarket y-pipe. You think the dealer will touch my car with the aftermarket y-pipe?
Also I have an Injen intake. No other modifications to the exhaust. Currently 92,000 miles, and have a 100,000 mile bumper to bumper warranty.
Thoughts on this? Take it in or no?
The SES code happened this morning. I think I may just wait and see if I throw it again.
Old Jun 17, 2004 | 01:44 PM
Max_Vader_2K's Avatar
good question. I need to know this as well.
Old Jun 17, 2004 | 01:51 PM
foodmanry's Avatar
Da Roller Coaster!
I think I am going to wait it out till I get closer to 100,000 miles and see if it pops up again. I just don't want to have to exchange y-pipes...PITA.
I've had this code before and they flashed the ECU, but that was at 18,000 miles or so.
Old Jun 17, 2004 | 01:53 PM
CRIS_Y2K_SE's Avatar
well i have a 2k and i had the rotten egg smell, car was shaking, i had ses, slip , and tcs lights on , so i replaced the spark plugs and ignitions coils , all the sysmptoms went away, now the ses light came on and gave me P0430. Auto zone cleared the ses light , but at times i have small faint rotten egg smell, very faint. any suggestions?
Old Jun 17, 2004 | 02:00 PM
foodmanry's Avatar
Da Roller Coaster!
rotten egg smell = catalytic converter leak
Old Aug 17, 2004 | 08:09 PM
foodmanry's Avatar
Da Roller Coaster!
Damnit...I just threw a p0430 code now. Before it was the 420 code and now the 430. I'm at 97,000 miles with only 3,000 miles to go on my warranty. Looks like I'll place a call into a local dealer to ask about if the TSB would be covered under warranty. If so, I'll have to switch out my intake and y-pipe...PITA.
Old Aug 17, 2004 | 11:44 PM
Maximaum Driver's Avatar
Bad smell?? Cat problem
P0420? It's under warranty as an emissions problem till 80,000 miles.. mine failed at 90 =\
The reg dealership cost is 100 bucks to have it scoped, but since it's a TSB, it *should* be free. Don't let them gank you. If they try, ask about the TSB.. =)
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
