Lowered Car, Now Having Issues. PLEASE HELP
I lowered my i30T with the H&R springs and stock shocks. I also have a addco RSB. Now, every time I go over large sized bumps, or going over a speed bumps any faster then a crawl, I get a large banging sound from the rear. Its like the shocks are bottoming out or something, which is strange as these springs are 25% stiffer, not softer?
-Shing
Originally posted by Shingles
stiffer springs doesn't mean anything... it doesn't mean you won't bottom out... it's the dampers/shocks/struts that does the the controlling... this is why it's said to not run after market shocks on the oem struts... because they were not designed to be used for lowering... there's not enough damping... that's what you are getting...
-Shing
-Shing
But funny thing is, I called H&R myself and asked them if it's okay to use stock struts with their sport springs on 5th gen max and even asked them if I needed to cut bumpstops..they answered no to both questions, I was like are you sure?? They said Yes!!!
What's the deal?
Tim
I noticed a second plug hanging when installing my fog lights and I figured it was for some light on the I30.
From experience....
i used to have a miata and i kept hearing a loud knock when i took turns too hard or hit bumps or potholes. i had no idea what it was and the first time it happened, it sounded like the whole chassis snapped or something. i went on like this for about a month until i finally figured out what it was. i was rotating my tires and there was a monkey wrench sitting im my spare tire. on hard turns it would bang against a side and over bumps it would bounce. i dunno if this will help you but here's an experience with loud unknown bangs.
OK, H&R DOES "claim" you can use stock shocks. Secondly, I will double check for loose items, but I don't think there are any. Last, lowering springs (Good ones at least, I guess) are NOT shorter. They have several coils (3) that are very close together. They are called dead coils, and once loaded, completely compress, and this is why the car is lower. I compared the H&R next to the stock units.
I'd really really hate to spend more money, and time to change the shocks and springs AGAIN, and still have this problem. Several people said these shocks should last about 60K, by then, I will have likely replaced the car with something else. I think it may be shocks too, but the car handles and rides great as it, just large pot holes and speed bumps make the rear sound like its going to fall off.
As far as those lights, the front ones are Fog lamps, and the sides are cornering lamps.
Mingo told me that the stock shocks on 5th gen maximas are stiffer than Tokico Blues!!!!surprised me!!! and of course we all know that tokico sux everywhere you go, you hear the same thing for Honda/Toyta!!!Weird!!
So, we are out of luck unless go for Cattman coil-over..which is way overpriced!
Tim
its hard to tell what your hearing, but ill tell you what i heard when i did mine and had some problems. i have a 3rd gen so some things may be a little different. i would hear large clanking noise comming from the rear when id go over bumps. i used tokikos and eibachs. eibach told me that the clanking noise could be caused from the dead coils clanking together since they are so closesly wound at the top and bottom. anyways to make a long story short, the upper strut seat was not alligned properly. to find that this was finally the problem i had to go through just about every possible mistake that could be making this noise. so here are some to look for:
-springs not seated correctly
-putting front springs in the rear (its stupid, but many people do it)
-upper strut assembly incorrectly installed(hard to tell unless you take it all apart)
-coils on springs clanking together(you would see the powder coating on the springs getting chipped off)-also i think this was kinda a line of bull eibach handed me.
-springs not compressed enough or too much when installed.
btw, i called both eibach and tokiko and bumpstops are not to be cut. i have not had any problems with the suspension since i fixed the problem.
hope this helps a little. sorry i couldnt tell you a specific answer.
What did you do to fix your problem? I still need the car re-aligned so I will look and ask if the springs are seated correctly. Also, how much would you need to compres the springs, just enough to get the strut housing together like it was? I know they are NOT over compressed, so I can rule that out. Any they are not backways as one set is a much larger spring the other.
I'll also look at the RSB once its on the lift. Furthermore, the I30T shocks are Stiffer like the Maxima SE, and H&R says they are designed for your stock parts (Maxima SE, which crosses with I30T). Hope this does away, very bad for a Luxury Tourang car to bang over bumps like an old chevy
Also,I think the sound is when its going down, not springing back up. I can't find anything loose in the trunk, so I think I can rule that out, but will check again. Its like the rear shocks botom out on large bumps? The fronts are fine. Thanks for the feedback so far guys. I have a few things to go on now.
not true~
That's not true at all about the OEM struts. Of course Nissan never said they were meant for them specifically, but that doesn't mean they CAN'T be used with lowering springs. However, after 40k on my OEM struts w/H&R springs, they finally drove me nuts enough to replace. Were they banging or rattling? NO!!! They were just allowing the car to bounce a lot over the road surface!
Saying his OEM struts are causing the banging noise is incorrect. My bet is with the RSB!
Good luck
SHUMAX
Good luck
SHUMAX
-Shing
-Shing
Only large bumps? It bangs? I had the sway bar before I lowered it, and it only started after I lowered it?
After lowering the car your rear beam is angled differently and when your suspension goes up its gonna come down a bit different. So your addco bar might be hitting something. Try taking it off to test.... I had a STILLEN RSB on my 98 lowered, never had a issue.
noise
check the side that the noise is coming from. it may be a loose shock/strut rod nut. the nut that screws onto the rod. was it ok at first then it started up later? this could mean something came loose, and it will be stuff at the top, cause the bottom only has that big bolt.
Originally Posted by NickStam
You should have cut the bumpstops if you didn't. The springs are shorter so they are going to hit that bumpstop under a smaller load than before.
Also, curious to kmow your impressions on the ride quality versus handling. Can I assume cornering is impressive now? Is the ride considerably harsher? Thanks.
It's probably the RSB hitting. See the bottom of this page:
http://www.win.net/audtatious/audio/tech/addcorsb.html
It's the right side bracket that holds the sway bar to rear beam. This bracket will hit the control arm above it. Mine used to hit even before I was lowered. I bet if you look at the bracket you find that it is bent on one cornor. What you need to do grind off about a quarter inch from the bracket and problem solved. Good luck.
You can confirm the problem by getting under the car and looking at the brackets on the beam axle - the one on the passenger side is probably showing marks from the panhard bar and may actually be starting to bend.
Fixing this is very easy - simply loosen the brackets on the rear axle and slide the entire bracket toward the center of the car an inch or two. You need to leave just enough room for the panhard bar to drop without hitting the bracket.
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
