I cleaned my MAF and holy sh!t !!!!!
Old May 24, 2004 | 01:31 PM
Kiosk's Avatar
I cleaned my MAF and holy **** !!!!!
I posted this on the older thread i created because of my performance problems with the car bogging down and lossing power after 3-4k RPM's... but wanted to bring out the topic again since it was such a huge improvement for me.
So I decided to take out the MAF and clean it with CRC Elektra-Kleen....when I took the sensor out it was pretty dusty in and around the sensor wire so I sprayed it at will thouroughly. Put the sensor back, reconnected battery (to reset ECU), and took car for a ride and.....
OMG!!!! all the bog down is GONE and the car just screams thru all the RPM's and I can even hear the VIAS kick in after 5k rpm....I am shocked, the car runs and pulls like a dream now, cant believe what a diff this has made!
I suggest that if you have similar problems and have not check out your MAF you might want think about cleaning it....I know Nissan says its not a serviceable part, of course becasue they can just have you buy a new one!!!
Old May 24, 2004 | 01:39 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
intresting.....where did you buy this elektra cleean stuff
and you just pray in it and no drying??
-J
Old May 24, 2004 | 01:57 PM
NewLoveI30's Avatar
I got some from home depot. You dont need to dry because it evaporates pretty quick.
When I cleaned my MAF and TB, I did not feel much of a difference.
Kiosk, did you remove the actuall sensor and spray it down? I only sprayed inside the MAF.
00MAXI's Avatar
TY-SPRAY Elektra-Kleen is a premium liquid alkaline detergent, foam controlled above 130 degrees F°. Safe on electric motor windings and other electrical insulation. Safe on multiple metals including aluminum and alloys. Cleans carbon, heavy grease, oils and other soils.
http://www.tysol.com/partwash.htm
Old May 24, 2004 | 03:16 PM
Kiosk's Avatar
I took the actual sensor out completely (u need special torx bit which I got from autozone) and just spray it down and in around the sensor wire. No need to dry because this stuff almost dries upon contact.....and reset the ECU of course
Old May 24, 2004 | 03:19 PM
hct67's Avatar
Pictures
Did you take any pictures of the MAF when you cleaned it, maybe some before and after pics?
Old May 24, 2004 | 03:23 PM
Cdriven's Avatar
How much for the bit? Is there a size # for the bit or anything like that?
Old May 24, 2004 | 03:27 PM
1phtmax's Avatar
the ses light didn't come on
Old May 24, 2004 | 03:29 PM
Kiosk's Avatar
I got the whole kit with like 10 of them for like 11 buxs...one of them fits (i think its T20).....
Sorry I didnt take any pics, the thing isnt that big to begin with. But i did see a lot of dust piled up around the sensor wire....prbly from the 108k miles on my car it was well overdue!
Old May 24, 2004 | 07:33 PM
00MAXI's Avatar
I'm at 111k I should do this. You say you got the Elektra kleen at home depot?
Old May 25, 2004 | 03:58 AM
Kiosk's Avatar
Its made by CRC and its called "Lectra-Motive Electric Parts Cleaner", I picked it up from Autozone. Good Luck!
Old May 25, 2004 | 06:20 AM
djPlayboy's Avatar
ive used tb cleaner on mine before i may try this stuff, im at 140+k right now and still runnin strong
Old May 26, 2004 | 09:25 PM
00MAXI's Avatar
So you use the star wrench thing, and then unclip the MAF, spray the stuff, and wallah? I went to AutoZone and found CRC "QD Electric parts cleaner” I presume the QD stands for Quick Dry. This should be this same thing right?
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
