How to change foglight with MAxxtuning lip
Old May 24, 2004 | 02:53 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
Has anybody with the Maxxtuning lip attemtped to change your foglights
my foglights wouldnt budge even before i had the MT lip and i checed now for clearence and it seems liek there isnt any room there
anybody try yet??
-J
Old May 24, 2004 | 04:49 PM
Triple8Sol's Avatar
I miss the .org!
You'll have to remove the front lip to remove your fogs. That means MT, Stillen, etc...
Old May 24, 2004 | 04:50 PM
MacAlert's Avatar
You have to push the light from behind it. It won't move if you try to pull it out from infront of it. Ask Polo, I think he installed his foglights after installing his MT lip.
Old May 24, 2004 | 06:24 PM
Qmax03
i got the stillen front lip and i cant take out the fog lights even when pushing from behind plus i got he whole kit molded so i dont wanna push to hard and crack the molding is there any way to chage the bulb w/o removal ?
Old May 24, 2004 | 06:31 PM
PoLo's Avatar
2-Wheelin it...
yeah had to remove the lip cause lining up the holes was just NOT happening...but i only moved it enough to put the fog in...since my drop is low enough for headaches, i don't remove the fogs from below. i find it 100x's easier to remove my headlight, and then i have complete access to the back of the fogs.
Old May 24, 2004 | 06:32 PM
Qmax03
Old May 24, 2004 | 07:31 PM
Cubanato's Avatar
well teh problem is my front lip is urethane glued in and bolted in
that sucker is nto coming off
so what your all telling me is i can never have foglights again now??
-J
Old May 24, 2004 | 09:46 PM
Hamy's Avatar
I ran into this same problem this week. For the life of me I can't get the fogs to come out. I wanted to put in a set of Ion Yellow bulbs but the suckers wont come out. Oh well...i'd rather not take the lip off.
Old May 25, 2004 | 12:20 AM
Triple8Sol's Avatar
I miss the .org!
Damn that sucks. If I installed a lip kit, I'd probably use some rivets in addition to tape or glue. So if you have to change a bulb or replace a cracked lens...shiet...
Old May 25, 2004 | 02:03 AM
MixSE's Avatar
Whiskey Tango Foxtrot
Not sure if this would solve the problem, but would taking off the front bumper help?
Again, I dunno, just trying to help out 2k2whitemaxi since his lip is glued on.
Old May 25, 2004 | 04:16 AM
chris'smax's Avatar
I had the same problem with my 2k touring lip. Just take the lip off, change the bulbs and slap it back on with double sided 3m tape and bolt it in or use rivets in original holes. Its not hard
Old May 25, 2004 | 04:20 AM
chris'smax's Avatar
-J
its probably that 3m double sided tape ****. Believe me that stuff is tuff but it will come off if you use some manly strumf and give it a good tugg. It won't hurt anything
Heat0212
Oct 24, 2020 12:36 AM
maxima-junky
Nov 10, 2015 09:12 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
