HELP my car is running like crap.
Old May 25, 2004 | 06:50 AM
msdins's Avatar
I removed the TB/IM restrictor on Friday and everything seemed fine until Saturday on the way home from a friends house. When I first start the car it will barely idle even shutting off once. If I ease in to it everything is fine until you reach 4500 rmps then it will immediatly cut back to 3000 and if I floor it the rpms will jump up to around 4200 and hover there but the car barely accelerates.
My car is a 2k auto with 70k miles.
Old May 25, 2004 | 09:30 AM
black2kse's Avatar
Make sure the hose that connects your air filter to the MAF is secure. Also check the hose that connects MAF to the throttle body. You may want to disconnect you bettery for a few hours as well. Good luck.
Old May 25, 2004 | 11:38 AM
msdins's Avatar
Ok, I will check that out as soon as I get home. Thanks.
Old May 25, 2004 | 11:43 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Sounds like tranny slipping to me...
Old May 26, 2004 | 08:37 AM
black2kse's Avatar
The tranny slipping shouldn't cause the car to shut off.
Old May 26, 2004 | 04:48 PM
msdins's Avatar
It does sort of feel like it when it happens but it does it when the car is in park and i just rev on it. I have checked all the vacum lines, reinstalled the intake adapter and reset the ECU and nothing seems to make a difference. Does it sound like a MAF problem to anyone?
Shane
Old May 26, 2004 | 07:16 PM
Y2K1JKSE's Avatar
hmm i was planning on doing this, this weekend but this is giving me second thoughts....you should ask ICE and the others that started the thread on the TB/IM restrictor thread since they know more about it...good luck though
Old May 27, 2004 | 03:08 AM
msdins's Avatar
Honestly I dont think there is a direct between this and the restrictor. I put it back in and still have the problems.
The strange thing about this it that it seems to be getting better on its own. Now I can give it a little more throttle before the bog begins and the RPMS will go to 5000 instead of 4500 before it goes back down.
Old May 27, 2004 | 04:47 AM
paralyse's Avatar
I Miss My Maxima
Removing the restrictor may have created a condition where the ECU needs to be reset -- try leaving the battery disconnected for awhile, as has been suggested, and see if that doesn't clear the problem up. If not, check out your MAF.
Old May 27, 2004 | 05:55 AM
msdins's Avatar
I left the battery off for about 12 hours and it didnt clear up the prob.. What is the normal (if there is a normal) amount of time to leave it disconnected?
Old May 27, 2004 | 06:11 AM
PoLo's Avatar
2-Wheelin it...
you consider maybe just putting everything back to normal and see if the problem goes away.
if it aint' broke.................
Old May 27, 2004 | 06:41 AM
Lawrenceismynam's Avatar
it sounds like MAF
Old May 27, 2004 | 06:47 AM
msdins's Avatar
That was the first thing I did but it didnt seem to help.
Old May 27, 2004 | 08:02 PM
00MAXI's Avatar
I had the Solenoids and the TCM replaced but I still get that horrible hesistation it's gotta be the MAF here's a useful thread about cleaning the MAF
Old May 28, 2004 | 03:22 AM
msdins's Avatar
That was my first thought but I have never had trouble with one so I didnt know what to look for. I will try cleaning it this weekend.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
MikesChevelle
Aug 9, 2015 11:50 AM
acw
Aug 7, 2015 04:20 PM
