Is this a record? haha... step inside please..
Old May 25, 2004 | 01:45 PM
mad2kmax's Avatar
A few of you know that I had recently disovered that my VIAS was malfunctioning through a long process. This is the link describing my problem...http://forums.maxima.org/showthread.php?t=312743
Well, SR20DEN and I got together yesterday to figure this thing out. All I can say is that he is the man...
Basically, we both knew that the VIAS passed the visual test of revving the engine past 5k and watching the L arm activate. So SR started disconnecting the assembly and it became apparent that it was broken internally. SR can describe the malfunction much better than I can so I'll let him do that later. Long story short, he removed the "power rod" WITHOUT taking off the intake manifold. He then did some cleanup, as there were some metal shavings from the malfunction lurking around in the manifold, and buttoned everything back together leaving out the power rod. Meaning that there was nothing to plug the short runners...
So SR then told me to take it for a spin... Wow. I can't even begin to describe the feeling of my max past 5k rpms. It's absolutly beautiful. I did feel like I lost some torque,though I didn't find out anything for sure until today...dyno time
Ok, here's the point of the title of this post. Keep in mind that it was 96 degrees with high humidity at the dyno:
whp: 202.70 torque: 185.34 SAE corrected
I dunno if this is a record or not for an all motor 3.0 but I like it. I don't even have headers yet...
Needless to say I did lose some torque and nothing was real exciting until 5k rpms, but on the track, I'd try to stay in high rpms.
Before anyone throws a fit, I have e-mailed SR the dyno's, before and after, and he will be posting them later. We also have a few ideas to get the hp # up even further, but that's later.
So anyone who thinks that their VIAS is not working, The visual test means nothing. The design is actually very poor as far as durability.
P.S. Has anyone in a 3.0 got higher #'s, all motor?
Old May 25, 2004 | 01:51 PM
mad2kmax's Avatar
Edit: My numbers for the first dyno were whp:178 torque: 197
Old May 25, 2004 | 01:53 PM
MrGone's Avatar
hehehehe, you've discovered the VI trick
When I put a auto ecu in Red92MaxSE's 5spd he said he thought there was more power (auto ecu for a VE will not operate the VI). I was glad to hear him say that because he felt it on his own and wasn't trying to 'look' for power gains, if that makes sense.
I just put mine on a switch, VI open (short runners runners), closed (long runners), and stock (ecu controlled).
Old May 25, 2004 | 01:54 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Sick numbers!!! Can I see the charts?
Max_Gator has 203.7whp/191.5wtq:
Old May 25, 2004 | 01:56 PM
IceY2K1's Avatar
This would be an AWESOME mod for the track ESPECIALLY once the TS ECU is released.
Old May 25, 2004 | 02:11 PM
Max_Vader_2K's Avatar
Not that I know of. Thats some nice numbers u got there. I want to take out my power rod!
Galo's Avatar
Maxima Pilot
Does this mean that physically removing the 'power valve' will actually increase HP substantially versus the power valve there and working designed?
In other words, having both runners open without the restriction from the power valve proper will get the best overall HP??
Old May 25, 2004 | 02:12 PM
IceY2K1's Avatar
It's the Power Valve....
Old May 25, 2004 | 02:15 PM
IceY2K1's Avatar
Yes, even when open the power valve is still blocking airflow into/out of the secondary chamber, hence my idea to "shave" it. However, SR has come up with a much better approach, at least for track use.
Old May 25, 2004 | 02:18 PM
so I could go outside right now take out the power rod with removing 4 screws and thats it.
Old May 25, 2004 | 02:21 PM
SR20DEN's Avatar
VQ Wizard
[edit by IceY2K1]
Removing the power valve is a PITA and I can't recommend it to everyone. There is more work than just removing 4 phillips head screws.
[/edit by IceY2K1]
Here on the chart, run # 001 shows a faulty VIAS and run #004 shows the results with the power valve removed.
Now all we need to do is remove his restricter plate, do the TB coolant bypass, add cattman headers, get a TS ECU with a 7200+ rev limit and I will do more work on his manifold. I don't see any reason why we can't get 220+ fwhp out of this engine.
Oh yeah, he still has the original spark plugs and coils. It's tuneup time.
Old May 25, 2004 | 02:23 PM
djPlayboy's Avatar
hmmm interesting, some more of nissans power robbing parts are found haha
Old May 25, 2004 | 02:24 PM
IceY2K1's Avatar
Man look at the top of that hp curve..WTF?!?
Old May 25, 2004 | 02:26 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
I should just yank mine out as well...my power valve, that is.
Old May 25, 2004 | 02:27 PM
SR20DEN's Avatar
VQ Wizard
You could... but that isn't the secret on the VQ35 manifold.
Old May 25, 2004 | 02:28 PM
IceY2K1's Avatar
[edit]
Corrected by SR~!
[/edit]
Old May 25, 2004 | 02:30 PM
jessemcd's Avatar
This sounds super cool! Are there any drawbacks, or will it be damaging to the car?
mad2kmax's Avatar
I don't know what happend at the top of the curve, but I do know that it is time for new plugs and possibly new coils. I plan on leaving much of this in SR's hands.
PearlWhtMaX2000's Avatar
ok i have no idea what any of this means. so is there a way i can increase hp for the track for like 5 min??
Old May 25, 2004 | 02:32 PM
IceY2K1's Avatar
Guys...guys...you SACRIFICE torque/hp below 5000rpm, but gain above it. LOOK at the RED lines before 5000rpm to see the LOSS.
This is a mod you probably don't want ALL the time, ie out on the street unless you plan on staying ABOVE 5000rpm.
mad2kmax's Avatar
Only downside that I can see is the lost of lowend torque and a little hp. But that shouldn't matter much at the track.
Old May 25, 2004 | 02:34 PM
mad2kmax's Avatar
Originally Posted by IceY2K1
Without taking off the manifold, the rod will only come out in one direction... saw it with my own eyes...
Old May 25, 2004 | 02:39 PM
IceY2K1's Avatar
Looks like 10-15whp and 20+wtq in some spots.
You're right....not a big deal at the track, but on the street you're feeling that right?
Old May 25, 2004 | 02:40 PM
djPlayboy's Avatar
im watching this now, i wanna know more abt this sounds interesting
Old May 25, 2004 | 02:44 PM
mad2kmax's Avatar
I do feel it on the street. It used to be a torque monster (198 ) but now it's exactly opposite. I haven't made up my mind yet if I want to keep it this way, but it will probably stay this way until SR and I get the most out of this motor...
Old May 25, 2004 | 02:47 PM
spirilis's Avatar
If this is what I think it was, I tried this using my vacuum pump on the VIAS fresh air port w/ VIAS control solenoid disconnected... I wasn't too impressed with the lack of torque
That was a long time ago, I forget how the top-end felt...
So what can occur which causes the VIAS to not work, despite the fact that the power valve is still opening? Looking at my VIAS, I don't see how the power valve can open/close WITHOUT the butterfly valves turning... unless the valves aren't linked together properly along the center rod?
SR20DEN's Avatar
VQ Wizard
You need to stop misleading people. It isn't going to be by any means 'easy' for most of the people here. There are some serious issues that have to be considered when doing surgury on that plastic manifold. I am not going to be responsible for telling people to do something they shouldn't be doing.
But if you insist that it is EASY then YOU go take the power valve out of YOUR car right NOW without removing the manifold.
IceY2K1's Avatar
You guys ROCK~!
Old May 25, 2004 | 02:49 PM
IceY2K1's Avatar
I changed that post...I see what the problem is now.
Old May 25, 2004 | 02:50 PM
SR20DEN's Avatar
VQ Wizard
The axle that connects the power valve to the diaphram breaks apart. So on the outside it appears to function normally, but inside the power valve isn't rotating. Instead it's just grinding metal and making a nice metal dust pile inside your intake manifold.
And this isn't the same thing as disconnecting the power valve. We're talking about actually removing it altogether to make even more top end power.
Old May 25, 2004 | 02:51 PM
mad2kmax's Avatar
You are right. Right inside of the manifold the rod had snapped and was no longer moving with the valve arm. In fact, it was carving little metal shavings out of the rod every time it activated... no good
Old May 25, 2004 | 02:52 PM
IceY2K1's Avatar
Damn slow response.
Old May 25, 2004 | 02:54 PM
Larrio's Avatar
The Definitive AE Master
hmm.. interesting mod. As for higher 3.0 numbers, irvine78 put down 204hp and 201ft-lbs all motor on the stillen dyno which is known to produce low numbers.
this is all with the VIAS still working and 100k miles on the engine
Old May 25, 2004 | 02:55 PM
IceY2K1's Avatar
Yikes~!
Can you get a picture of the broken part?
mad2kmax's Avatar
You guys ROCK~!
Thanks, although it might be a slow process as funds are a little low...
Now we need you to hurry things up with technosquare so I can raise the rev limiter
Old May 25, 2004 | 02:56 PM
spirilis's Avatar
OUCH!!! Man I hope that's not what's wrong with mine
Speaking of which, I guess the only option for those who have broken VIAS rods is to remove it or buy a whole new manifold?
Old May 25, 2004 | 02:57 PM
SR20DEN's Avatar
VQ Wizard
Well thats why we're here. We want to get some more feedback from others as to what they have made. However when these other numbers arrive we need to see a mod list for each vehicle. That includes you Nathan.
Old May 25, 2004 | 02:58 PM
IceY2K1's Avatar
There's no such thing as hurrying up TS...LOL!
I'm working on them though. Issues including NOW I think a broken VIAS keeping getting in the way.
mad2kmax's Avatar
I need to dyno in cooler weather and with a tune up.... rest asured that we WILL beat those numbers...
Old May 25, 2004 | 03:01 PM
mad2kmax's Avatar
My mods are shown by my sig on the first post...
Place Racing CAI, Cattman Y-pipe, random tech high flow cat, Cattman full cat-back exhaust... that's it as far as performance
