Short thow shifters?
Old May 28, 2004 | 11:12 AM
rchun08's Avatar
Does anyone know if anyone is making a short throw shifter is being made. I have a 2002 maxima 6 speed. I know the inifinti g 35 has a short throw. I wonder if that shifter could be bought and put on my car. Any one know more? I think the g35 one is the same setup. dont know.help
thanks
Old May 28, 2004 | 01:30 PM
Y2K2Driver's Avatar
There are none and there doesn't look like there will be one for a while, if ever. The G35 is totally different setup, so no, it will not work. There are companies that worked on STS for the Altima and SE-R, but it seems the Maxima differs enough that they couldn't get it to work on our cars and just gave up. There is, however, a bushing kit coming out from Energy Suspension that may make the shifts more crisp. It looks like the best option, even if it is the only, for the time being.
Old May 28, 2004 | 01:33 PM
PoLo's Avatar
2-Wheelin it...
installing as we speak....
Old May 28, 2004 | 04:59 PM
PoLo's Avatar
2-Wheelin it...
just finished installing the shifter bushing kit. only took me long cause i had no idea what i was doing. but i can prolly knock all this out in about 20 minutes next time.
this may not shorten your throw, but if anything, it will help you get more precise shifts. these bushings are nice. firm. the stick doesn't shake anymore. i like this. so far, energy has my thumbs up for final production of these. i will explain more in my shifter bushing thread.
Old May 28, 2004 | 06:43 PM
5 spd's Avatar
I like my short shifter
Old May 30, 2004 | 02:01 PM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
Is there any reason they won't make the short throws for our 6-speeds? Why are they not bothering? It couldn't possibly be that hard. I think the 1st person to make one will make a fortune off us.
Old May 31, 2004 | 06:26 AM
ABS's Avatar
ABS
I think it is that hard. Have you opened your dash to take a close look at the stick? There is a whole spring loaded assembly right on the shaft of the stick which provides a "reverse lock out" when you don't pull up on that plastic ring. Also, the mounting location for the cables could be problematic . . . If you move them, you might also have to change the lengths of the cables. These are technical problems which could dissuade a company from spending much money on R&D when they could get a bigger bang for the buck by developing a simpler STS for another vehicle instead . . .
Old May 31, 2004 | 07:45 AM
PoLo's Avatar
2-Wheelin it...
the STS is currently being worked on, you didn't hear that from me. that, combined with the energy suspension shifter bushing kit, is goign to be one sexy clutch.
Old May 31, 2004 | 08:16 AM
mjg's Avatar
mjg
speaking of clutch, when will be get high performance clutch and flywheel setups????
Old May 31, 2004 | 08:37 AM
1BADMAX's Avatar
Well since they did it for the Altima, maybe now when the Altima SE-R is comes out they'll make one for it, in which it should work for us too. I wouldn't hold your breath though.
Old May 31, 2004 | 09:19 AM
ABS's Avatar
ABS
I'd seen your posts regarding the Energy Suspension bushings - they sound really great. But this new information sounds even better! We really need that STS for the '02+ 6 speeds! Do you have any additional details for it?
Old May 31, 2004 | 10:13 AM
Deckdout2's Avatar
Play with my balls
more details would be great
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
