Panicking! Please Help...Is my electrical shot?
Old Jun 7, 2004 | 06:49 PM
steelymatt's Avatar
I went to start my car. My highs went on instead of my normal headlights, then the lights went off. No matter what setting I use, Off, On, or Auto, I can't get them to go on now. All I can get is the blinkers. My hardwired radar detector is displaying High Voltage. I tried to drive it and my ABS light came on for a minute and then went off. What is going on?
Please help.
Old Jun 7, 2004 | 07:01 PM
saxdogg's Avatar
First ? is have you done any mods or messed with anything prior to this?
JP
Old Jun 7, 2004 | 07:04 PM
steelymatt's Avatar
No real mods.
I have a remote starter that's never given me problems in the 3 years I've had it.
I had my ECU reflashed for the P0420 Catalyst Emissions problem a few weeks ago.
Old Jun 7, 2004 | 07:10 PM
schernov's Avatar
check voltage regulator on the alternator....
Old Jun 7, 2004 | 07:11 PM
saxdogg's Avatar
Check the obvious's...fuses and relays...maybe a ground issue? Check the chassis grounds and maybe have your battery tested? I'm not an electrical expert, however. Good luck!
JP
JP
Old Jun 7, 2004 | 07:55 PM
steelymatt's Avatar
Do you think that it is safe to drive the car to the shop or do I risk damaging something?
Old Jun 7, 2004 | 08:55 PM
MiniRX7's Avatar
DON't drive the car...
Its not a grounding issue.. DON'T start the car, and tow it in..
If you keep driving it, you could risk burning your ECU, and all sorts of sensitive sensors... and it will be big bucks.
Sounds like the alternator voltage regulator
Old Jun 8, 2004 | 11:13 AM
steelymatt's Avatar
I brought it to the stealership. They say my alternator went bad which burnt out my lights. This is a good opportunity for me to try out the Silverstar bulbs. Thanks for your help guys.
Old Jun 8, 2004 | 11:26 AM
saxdogg's Avatar
Good calls!
Glad it worked out.
JP
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
